Valve cover bolts
- bkitchen
Valve cover bolts
09 May 2007 18:56
I just checked and adjusted my valves on the kz900 but can someone tell me how tight the valve cover bolts should be. If someone has a manual with the torque specs. that would be great.
- Sandy
- Fly High,Tony
- RonKZ650
Re: Valve cover bolts
09 May 2007 20:06
I'd go less personally, as valve cover bolts will strip at 8 ft-lbs (96 in-lbs) trust me. Go 5.5 ft lbs (about 65 in-lbs). It does absolutely no good overtightening the cover as it won't help on leaks and the bolts won't vibrate loose at 5.5 ft-lbs. Go by the manual, but get your helicoils ready at 100 in-lb because you're going to need them. Same with the camshaft caps, don't care what the manual says as they will strip at torque over 65 in-lb. Aluminum in the head is very soft and seems to get softer with age and extended heat. They will strip, trust me as I've put a lot of covers on over 3 or 4 hundred thousand miles on KZs.
- donthekawguy
09 May 2007 21:00
And don't forget your anti-seize!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- cuddies
09 May 2007 21:53
Hey thanks for this thread, I was wondering the same thing!
Sorry to hi-jack the thread, but I have another question, too.
How many FOOT lbs. does the the 'cam-holder' (on each cam there is like this plate thing that goes on each side of the cam, and there is 4 bolts in each cover). How tight do those go?
- bkitchen
09 May 2007 22:13
That is exactly what I was looking forit seemed like these would strip out in a minute thanks ronkz650.
- donthekawguy
10 May 2007 05:21
cuddies wrote:
I think your talking about the cam caps. They should be a light 7 lbs. Go slow and be carefull and it should work out. Damn I shouldn't have said anything cuz I'm putting mine back on next week and I'm sure to strip out at least one now!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
