Engine Noise
- letthegoodtimesroll
Engine Noise
09 May 2007 13:12
Can worn valve guides cause a ticking/knocking noise when the engine heats up? I have been chasing this noise for sometime now and can't figure it out. The valves are all set to within spec, cam chain tension is good and the timing is on. In the morning when it is cool there is no noise, or when you first start up the bike but as it gets warm on the ride home (temp 29C/85F) the noise can be heard. Any help is appreciated. Thanks!
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- Duck
- e vica na i sau na ga
Re: Engine Noise
09 May 2007 14:15
Without hearing, it's difficult to say but perhaps it's premature ignition. Try some higher octane fuel or if already running highest, try retarding timing a little.
-Duck
-Duck
- pstrbrc
- '81 GPz 1100 project
Re: Engine Noise
09 May 2007 14:25
Yeah, what Duck said. It sounds like pre-ignition. First step is a tank of higher octane gas. However, you might want to check the plugs first. Do a throttle chop when you've got it warmed up and making noise. Then pull your plugs (do all four, just in case) and check with
Dan
Go down to page 61 for an explanation, then check on page 62. By the way, lots of stuff to learn there, so don't stop with just reading your plugs.
The likely possibilities are lean mixture or too much advance/not enough octane. Learning to read your own plugs is much better than taking the advice of somebody who isn't there, and won't be there if and when it breaks down.
Dan
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
