KZ1000J Oil Light
- vrdw
KZ1000J Oil Light
08 May 2007 12:38
Hi:
My '81 KZ1000J Oil light goes on at low revs only after running for twenty minutes. Engine is hot.
I ran a test with a oil pressure gauge and the reading was erratic between 1 and 6psi at 3000RPM (the book says 2.8psi is normal) Otherwise the bike starts and runs fine but I'm not riding it until I sort this out.
Nothing makes sense so wondering if anyone else has any ideas. Thanks Viv Ottawa
- MDawnz1
Re: KZ1000J Oil Light
08 May 2007 12:51
Change the oil and filter ..
borrow another gage and test again ..
If it reads the same ..
Start saving ..sorry ..
By the way , do you have a cooler or any other non stock lines on it ?
If so bypass them .
If so bypass them .
1974 Z1a, still 903
- vrdw
09 May 2007 16:08
I had changed the oil and filter before testing with the gauge so I guess you're saying the engine's shot?
VRDW
VRDW
