Cam Cap Torque Conversions
- reborn650
04 May 2007 23:22
Hey gang - Has anyone got the torque settings for 650 camshafts. My torque wrench is in ft. lbs and gigakilojewelsnewtons or some crazy setting. The factory mechanic's manual calls for 75 inch/lbs, what is that coverted to foot lbs?
-1998 Jeep TJ Wrangler 4.0...
- 77KZ650
Re: Cam Cap Torque Conversions
04 May 2007 23:31
im pretty sure 12 inch pounds = 1 foot pound. so going by that, 6.25 foot pounds = 75 inch pounds
might want to get that double checked though, i could be way off
07 MDP Rookie of the Year
- dkmk
04 May 2007 23:41
Colin, to convert to ft/lbs from in/lbs, just divide by 12. Here is a handy conversion tool, just save it (then extract it, as it is a zip file). I keep one on the desktop of all my systems.
Converter
Converter
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- reborn650
05 May 2007 00:25
Thanks guys. It was too late for my brain to function in a logical manner. The answer was obvious:)
Dave, my cams came in today as well as the stuff from Z1. If you are out and about tomorrow give me a shout and I'll get you the allen head bolts.
Cheers-Colin Firth
Cheers-Colin Firth
- BSKZ650
05 May 2007 04:25
I would not try to use a foot lbs wrench when it calls for inch lbs, they are not that accurate at the bottom of the setting scale, at least mine are not
77 ltd1000, current rider
76 kz900, just waiting
- N0NB
- Blue handles better
05 May 2007 05:24
A lot of the fasteners on a KZ require torque in inch pounds. I have access to a 3/8" drive torque wrench calibrated in inch pounds and my own 1/2" drive torque wrench calibrated in foot pounds.
A person really needs access to both sizes before doing serious work on these bikes.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- RetroRiceRocketRider
05 May 2007 06:37
BSKZ650 wrote:
Agreed!
I found this out the hard way (read: expensive) when I used a foot-pound torque wrench to tighten down in inch-pounds the ($90!) outlet valve onto the piston rod of a paint sprayer at work - SNAP! :pinch:
The shop ended up having to "eat" that valve.
It's a good thing I'm responsible for my own parts inventory, as that valve mysteriously disappeared from the inventory list. :whistle: :laugh:
Agreed!
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Duck
- e vica na i sau na ga
05 May 2007 07:11
75 inch lbs is a gallon of milk on the end of a 9" wrench.
Make sure the threads are clear over the engagement length.
-Duck
-Duck
- steell
05 May 2007 07:29
Torque wrenches are generally not accurate at the top and bottom 10% of their range.
If you want to be absolutely sure that your torque wrench is accurate, or you want to calibrate it for a specific torque setting, it's really simple to do.
6.25 foot pounds (or 75 inch pounds) is 6.25 pounds of force applied 1 foot from the center of the bolt. So clamp the square drive end of the torque wrench in a vise with the handle parallel to the ground, hang a milk jug containing water that has a total weight of 6.25 lbs on the handle one foot from the center of the square drive, and check the setting on the torque wrench. If it is a beam type just look at the pointer, if it is a click type, just set it so it clicks.
If you don't have a vise, then just put the torque wrench on a lugnut on one of the wheels on you car, anything that will not move when you apply that torque to it will work.
Post edited by: steell, at: 2007/05/05 10:31
- wireman
05 May 2007 08:08
i could be wrong but last i heard a gallon of water was closer to 8 lbs than 6;)
- OKC_Kent
05 May 2007 08:31
Duck wrote:
I'd love to see you work on your bike Duck!:woohoo:
-Duck
Cashion, OK
78 KZ650 B2 85,000+ miles
- reborn650
05 May 2007 08:50
wireman wrote:
Isn't Google wonderful???
Weight of One Gallon (U.S.) of Water, Gasoline, and Ethanol
* 1 gallon of water equals 8.33 lbs.
* 1 gallon of gasoline equals 5.8 to 6.5 lbs.
* 1 gallon of ethanol equals 6.59 lbs.
One gallon of regular beer equals 7.25 lbs, light beer 6.78 lbs.
I put that in just to see if anyone noticed:)
Source: U.S. Dept. of Energy. Fuel From Farms: a Guide to Small Scale Ethanol Production. May 1980. Page D-3.
Cheers - Colin Firth-Ontario Canada
