KZ700 locked up?
- loudhvx
Re: KZ700 locked up?
06 May 2007 10:34
Sounds to me like time for a 750 motor. It will be less money and effort to get a decent KZ750 motor, no?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- themachine
06 May 2007 18:51
loudhvx wrote:
or you could jam in a 1000 engine. :evil:
i concure, search ebay or the local bike yard.Sounds to me like time for a 750 motor. It will be less money and effort to get a decent KZ750 motor, no?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- 84kz700
06 May 2007 18:54
already done, read my other post about the kz750 shaft drive......
THX FOR THE ADVICE EVERYONE!KEEP THEM COMING
- OKC_Kent
06 May 2007 19:53
I have an 83 manual that covers the ZN700A. It looks like in the oil pan area there is definitely 2 ball bearings, 2 springs, and maybe two circlips.
The oil filter mounting bolt assembly; It has a small spring on top of a ball bearing and it's held in place with a pin.
The second ball bearing and spring are in the Relief Valve Assembly. The picture is small but it appears a small circlip holds the works together.
I see the second circlip belongs on the oil pump.
Cashion, OK
78 KZ650 B2 85,000+ miles
