Mods for the biggest HP gains=GPz550
- vintage1
03 May 2007 11:54
What are some modifications for the biggest HP gains to be found in the 84-85 GPz550 other than exhaust and pod filters. I figure porting the intake bowls and enlarging/smoothing Int/Exh passages should help.
R.C.
R.C.
- wireman
Re: Mods for the biggest HP gains=GPz550
03 May 2007 15:09
i think the gpzs already have a pretty decent head right out of box and hogging things out is not always the best thing to do,you end up loosing power if not done right.id say to see if you can find a set of drop in style cams and maybe tweak you carbs a little;)
- loudhvx
03 May 2007 21:47
Wiseco 615 kit.
Like Wiredood said, the heads are pretty good already. There are various cams available out there. You may even consider Zephyr 550 parts, like cams or carbs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- vintage1
16 May 2007 07:22
I was thinking of using a set of KZ550 cams. I'm thinking this will make the bike stronger at the bottom end without changing gearing? I'm not looking for top speed or top end as I like strong 0-60 blasts!. I like the way the my standard 550-A pulled at the bottom and midrange. With the higher compression on the GPz should make it scream! Will these cams do the job??
- pyxen
16 May 2007 07:55
Then you're not looking for more HP.. you're looking to increase torque and low-end power.
HP is really only used to get more top-end speed.. isn't it?
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- loudhvx
16 May 2007 11:20
My friend has a gpz550 with KZ550 A cams. Yeah, it's nice and smooth, pulls vey well off the line, but wheezes out at higher RPMs. It's great in the city, especially with a passenger, but not as fun on the highway.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Lorcan
- Speed Loony
16 May 2007 12:23
The Wiseco kit works great on that bike.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- vintage1
30 May 2007 10:59
Right! more torque and all around power before 8K RPM for back country roads. Top end is not as much fun as smoking through 4 gears from a dead stop. My old KZ550-A4 model was a blast in the lower gears!
- GPz750KS
30 May 2007 11:12
You need NOS.. Two Bottles. The Big ones. And you need it by tonight....
or....
Tow Rope and a ZX14....
Sorry, I'm bored at work... I don't have really any good answers for you. Looks like the rest have pretty much answered the question. However, there is no sustitute for displacement.... Engine kits and compression increases would make the biggest gains.
Richard Z.
or....
Richard Z.
- Faughn
- Don't drink the Kool-aid!
30 May 2007 11:33
GPz750KS wrote:
:woohoo: :woohoo: LMAO
Richard Z.
- themachine
30 May 2007 15:31
turbo!
turbo!
turbo!
turbo!
turbo!
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- N0NB
- Blue handles better
30 May 2007 16:03
Swap out for a GPz1100? :whistle:
I can't think of anything else but a wisecrack, sorry.
Odds are that while keeping the current displacement, you won't achieve much more than a ten percent gain before you have to get fairly radical with the mods.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
