305 refuses to go over 60mph
  • lucianmburns
  • lucianmburns's Avatar Topic Author
02 May 2007 22:31
#136659
I have a 1982 305 and this is my first bike. The tach is broken so I don't know exactly where I am in rpm's but it is certainly not red lining at 60 in 6th gear, but just starts lurching if I try to push it past this point. I'm thinking it's probably starving for fuel but am unsure. Any help with diagnosis and fixes would be great. Thanks.
  • austin3119
  • austin3119's Avatar
Re: 305 refuses to go over 60mph
02 May 2007 22:43
#136666
Welcome to the forum. Ouch, kind of tough to ride on the freeway at 60 mph. I can barely walk and chew gum at the same time, so my advice is limited. Have you tried rebuilding the carbs? I'm sure many others will chime in with better advice.
Also, make sure nothing is blocking the intake at the air filter. I know that one from experience.
Good luck.:)
Post edited by: austin3119, at: 2007/05/03 01:44
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
02 May 2007 22:43
#136667
Welcome to KZR!;)
Does Your bike have a fuel filter on it?
Is the tank clean?...petcock clean?
Float height set properly?
How long did the bike sit for,if it did?
Points good?(if it has points...not sure on the 305)
Timing issues perhaps?
There could be a list of things causing the bike to be lacking power in that range...need more info,Bud.
1977 KZ1000 A-1
  • apeman
  • apeman's Avatar
03 May 2007 10:03
#136781
I am with Sandy on this. There are three things that could be the problem:
FUEL: either a kinked line, clogged filter, or clogged carb passages. Disassemble, clean, install a new filter (and maybe new lines -- they do disintigrate from the inside).
AIR: clogged filter, or obstructed intake
SPARK: You will notice a weak ignition system especially when it is under load, at higher RPMs. Make sure you have a good blue spark, and ensure that the points are moving freely. Also, dissasemble, clean and lube the mechanical advance mechanism.
Let us know what you learn.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • newbikekiller
  • newbikekiller's Avatar
03 May 2007 10:08
#136785
Serious performance issues on bone stock (I assume your bike is bone stock) low mileage bikes are usually FUEL related (as in carbs/petcock/fuel filter), a dirty air cleaner, or
and in my experience this is most likely
a rusted, frozen, timing advancer.
It seems like most folks out on the streets don't know that the timing advancer exists, and as the years go by these bikes (especially the smaller ones like yours) are used only to learn on - and the bikes "performance" is not taken into consideration. Hence no one ever bothers to get the machine running "good".
Beware, bikes with frozen timing advancers will run very very hot hot hot. This is a dead giveaway!
  • loudhvx
  • loudhvx's Avatar
03 May 2007 11:49
#136811
First two likely probs are carb or the ignition advancer.
Make sure the diaphragm at the top of the carb has no holes or tears in it.
Make sure the advancer advances.
  • donthekawguy
  • donthekawguy's Avatar
03 May 2007 17:45
#136898
It's a 305 so be thankfull you get it up to 60. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • themachine
  • themachine's Avatar
03 May 2007 19:48
#136932
is that you nick?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • lucianmburns
08 May 2007 12:46
#138257
Was out of town for a bit. It was the air filter. Got a new one and now it runs great. Thanks for all the help.
