kz turbo project
- jordan
kz turbo project
30 Apr 2007 20:03
I have an extra 750 motor, and i decided o do something crazy. I would like to turbocharge this bike. Can this be done? Any help or suggestions. So far the basic plan is to make a turbo manifold, use a small, easy-spooling turbo from an eagle talon. then make an intake manifold and run it to the turbo.
I dont expect the stock motor to last long, but if i like the setup i will build up the motor with low compression pistons, etc.
Basically i just want to go from one end of the track to the other a couple times at a fairly good time. What troubles will i run into? such as timeing, carbs, etc.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- wireman
- z1rick
Re: kz turbo project
30 Apr 2007 21:03
Try here:
tinyurl.com/2k5458
tinyurl.com/2k5458
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- 77KZ650
01 May 2007 10:23
www.750turbo.com
I would say you have the right idea, you could use the EFI system from a 750 turbo, or a gpz1100 and control it with megasquirt. you wont be able to run much boost with stock pistons, but the wiseco 810 kit for the turbo will drop it down in compression and they are much stronger forged pistons
keep us posted
keep us posted
07 MDP Rookie of the Year
- JAILBAIT
01 May 2007 11:58
Are you trying to blow through carbs or draw through the turbo. Your are going to need to get a fuel pump and a return style regulator that is boost referenced. Like 77kz650said go with low compression pistons.
- mark1122
- Keep twisting it
01 May 2007 19:18
I saw 2 turbo gpz750, 1982?for sale last week ,if your interested.I'm in canada though.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
01 May 2007 19:50
GPz750 Turbo was only made for two years, 84 and 85.
