Engine Forum
Engine forum is a tech forum for "Engine" topics.
1983 KZ750-K LTD Been in storage for 8 years, what now?
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: 1983 KZ750-K LTD Been in storage for 8 years, what now?
07 May 2007 16:09
#137998
fenlon wrote:
. . . I removed the gas tank and emptied the gas and checked out the petcock, which looks to be functioning fine.
fenlon wrote:
The bike has been in storage for about 8 years, and this being my first bike, I have no clue where to begin.
What did the fuel smell like when you drained it?
Resign yourself to the fact that the carbs are probably full of something that started out refined and has since degraded to something less than volatile and combustible. Even if there is anything in the bowls resembling liquid, there have been ample opportunities in eight years for what used to be fuel to crystalize and stagnate. Additionally, the stuff will not atomize due to probably clogged metering jets and passages.
You could pull the carburetor drain screws and turn on the tank prime position to see if fuel flows at all. But it is likely that the floats, needles and seats are going to give you trouble if the probablegoo is not removed from them. In a bad case scenario, the throttle slide could get stuck on a running engine.
No shortcuts to restoration/reconstitution.
