Maybe clutch adj.-finding neutral
- CBerryment
29 Apr 2007 13:36
Got another mystery gremlin on my 77 kz750 twin. I adjusted the clutch. I works well.. beter than last season.. EXCEPT that finding neutral is a pain... in fact, many times I cant and have to kill it... Here is the strange thing, when it is running, no neutral... Turn off the engine, can find neutral like it was always there waiting for me!!! Whats this mean? THANKS CSB
- Sandy
- Fly High,Tony
Re: Maybe clutch adj.-finding neutral
29 Apr 2007 14:11
Sounds like You maybe DON'T have the clutch adjusted properly....possibly?:huh:
How much freeplay is there on the lever when You have it adjusted?Too much slack(freeplay)will cause this.
Have You adjusted it down at the clutch cover?
1977 KZ1000 A-1
- CBerryment
29 Apr 2007 15:07
Sandy:
I cede that I may not have adjusted it correctly
I meant to say that it WORKS correctly in my view aside from the neutral problem
Which is more a pain in the tuckus than anything else...
I have adjusted the clutch both on the handle and under the clutch cover. There does not seem to be much slack at all. there is a few millimeters. But then again, it had a lot more last season, so maybe I need to loosen her up...
Why would it be easier to find neutral with the engine off is my question though? It clicks right over neutral when running... I turn off the engine and click her up or down and the beautiful green lit pops right on...
- CBerryment
30 Apr 2007 08:14
Got it. Just took a night to sleep on it.. got up and tweaked it a little... Next project: COIL MOD!!!! and new coil...
