Welded Crank
- tuxedotito
Welded Crank
25 Apr 2007 05:56
Greetings,
Been checking the Forum/Archive and can't find exactly what I am looking for.
When a crank gets 'welded', does each individual slab side get welded-up as it is pressed into place? If so, how would a shop keep the crank assembly from possibly moving about due to heat etc.? In other words, what are some generally accepted steps for welding a crank as I am sure different shops will vary in specific techniques?
Many thanks to all...
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- wireman
Re: Welded Crank
25 Apr 2007 06:04
you have to make sure its straight 1st.running a long straight rod through the small end of rods and clamping it down should hold things straight while welding the pins in place;)
- tuxedotito
Re: Welded Crank
25 Apr 2007 06:08
Thanks!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- Sandy
- Fly High,Tony
Re: Welded Crank
25 Apr 2007 07:54
I believe the KZ1000 uses a 17mm rod...not too sure about the GPZ1100 though.
1977 KZ1000 A-1
- steell
Re: Welded Crank
25 Apr 2007 07:59
Sandy wrote:
83 was the first year of 1100 to use the 18mm wrist pin, all prior years were 17mm.I believe the KZ1000 uses a 17mm rod...not too sure about the GPZ1100 though.
- Sandy
- Fly High,Tony
Re: Welded Crank
25 Apr 2007 08:06
Well there Ya have it!
Right on,Stevie Wonder!
:laugh:
1977 KZ1000 A-1
