J-Engine Good?
- Higgy
J-Engine Good?
22 Apr 2007 08:30
The guy who gave me this '81 KZ1000 said it had a "J" engine, which at the time meant nothing to me. The first several letters on the engine are: KZT00JE, does that mean this is a J engine? What's so special about it?
- wireman
Re: J-Engine Good?
22 Apr 2007 09:36
its the engine series after the kz,good cylinder head;)
- Kiwiz
Re: J-Engine Good?
22 Apr 2007 13:00
the link tells you all you need to know:
www.aperaceparts.com/tech/techkz1000.html
Post edited by: Kiwiz, at: 2007/04/22 16:01
- themachine
Re: J-Engine Good?
24 Apr 2007 03:20
IT IS VERY GOOD ENGINE YOU MUST TRY!
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- Higgy
Re: J-Engine Good?
24 Apr 2007 09:36
Thanks, Guys.
I pulled the crusty carbs off it and gave it some oil on top of the cylinders. Then I cranked it over with very little trouble using my marine battery and jumper cables. No telling how many miles on the engine since its not the original.
Once I get the carbs cleaned and the wiring sano I will try to give it a start.
