starter noise
  • Booncha57
  • Booncha57's Avatar Topic Author
Re: starter noise
20 Apr 2007 12:36
#132301
i had that sprocket cover off the other day and tried to pull the starter out and it didnt want to move so i just left it. i took off side cover, top cover, and 2 or 3 bolts holding it in but im guessing it can get jammed on the gear in there pretty good. is that all i need to do to get it out??
  • The Milkman
  • The Milkman's Avatar
Re: starter noise
20 Apr 2007 14:44
#132324
The starter is a tight fit in its hole with a big O-ring on it to keep the oil out. You should be able to tap the right side end of it and start is rocking to get it out
Ride Safe
