1978 KZ400
  • JONNYKZ
  • JONNYKZ's Avatar Topic Author
1978 KZ400
16 Apr 2007 14:05
#130820
Hello, I have a 1978 KZ400. At light accel the engine pops and misses out. If I give it more throttle then it clears up and runs Great. If i go to Full throttle from take off it runs fine. Sometimes it pops out of carbs at idle. The engine is rebuilt with LESS THEN 50MILES. Any Help would be nice
  • btchalice
  • btchalice's Avatar
Re: 1978 KZ400
18 Apr 2007 05:01
#131432
try spraying wd40 on the carb boots when its idling to check for vacuum leaks
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 1978 KZ400
18 Apr 2007 05:07
#131436
Hi Jonny, welcome to the site. Terry is right, the carb holders may not be completely sealed. You may also have reused the exhaust gaskets and this may be causing the popping... ANY air in the combustion chamber from a leak will cause the popping. Could also be a missing vacuum cap or vacuum hose leak from the carbs, etc.
  • JONNYKZ
Re: 1978 KZ400
18 Apr 2007 10:52
#131543
Hello, Well thanks for all the information. I will try that tonight and keep yall posted about what I find. Thanks Again.
  • JONNYKZ
Re: 1978 KZ400
19 Apr 2007 12:52
#131910
Hello, Well I sprayed some carb cleaner on the intake boots and around were the boot meets the head. And when I did this the engine died out. Do any of yall know were I can purchase these boots new at a good price? Thanks, Jonathan
  • JONNYKZ
Re: 1978 KZ400
27 Apr 2007 17:44
#134813
I just put some new intake boots on my motorcycle. And they solved the problem of popping at light acceleration. But I have to have the motor all the way RETARDED, or it will not idle, and will pop out of the carbs. I have a performance ignition system... with One Automotive Coil for each cyl. with a Automotive Ballast Resistor and a New Automotive Condensor. Do any of yall have any idea how to fix this problem.Even with the it all the way Retarded it still doesnt run like it should.
