valve clearances check
- squints
16 Apr 2007 11:44
I'm a newbie, but I am learning. Slosly. Please finish this sentence.
"You know you have to adjust your valve clearances when..."
I know they probably need adjusting anyway seeing as its a 25 year old bike, but I was wondering if there are any warning signs sounds to watch for.
Thanks all
Thanks all
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
Upstate NY
- mariozappa
Re: valve clearances check
16 Apr 2007 12:27
The engine will die when you come to a stop and might not start until it cools down.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- N0NB
- Blue handles better
16 Apr 2007 12:27
You warm it up and the compression gauge doesn't move off 0! :whistle:
Or, once warm it has almost no power.
Checking the tappet clearance is more a function of engine mileage rather than actual age. However, doing it is a good idea, if for no other reason than your peace of mind.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- OKC_Kent
16 Apr 2007 12:28
Low compression, poor performance
Cashion, OK
78 KZ650 B2 85,000+ miles
- H1Vindicator
Last edit: 20 Feb 2013 18:58 by H1Vindicator.
- KaZooCruiser
16 Apr 2007 13:17
squints wrote:
. . .the .003" feeler gauge won't fit into the gap. Or, when .008" is still loose.
Age is not the indicator. This is preventive maintenance to avoid burnt valves or other problems. If you have a clearance on the wrong side of minimal, you may lose a cylinder a long way from your tools and help. A hot valve can melt, dropping into an engine, ruining it, and your fun.
You don't wait until an oil light comes on to check your oil; you don't wait until engine problems manifest to check your valves.
I'm a newbie, but I am learning. Slowly. Please finish this sentence.
- N0NB
16 Apr 2007 13:31
Good advice, Kazoo, good advice.
Nate
- Sandy
- Fly High,Tony
16 Apr 2007 16:26
Popping out of the pipe during normal cruising.
In other words,it doesn't have to happen on deceleration,where these bikes are "pop"ular for that.Lower rpm cruising and popping would be an indication.
1977 KZ1000 A-1
