Engine Forum
Engine forum is a tech forum for "Engine" topics.
valve clearances
  • bison
  • bison's Avatar Topic Author
valve clearances
16 Apr 2007 10:35
#130741
I recently measured my cam/valve clearances and I noticed something a little strange
All of my clearances on my intake cam were under the spec. In fact I could not get a .04mm feeler gage to fit under any circumstance on all of the lobes
Then on my exhaust cam, all of my clearances were quite high, they were all above 0.15mm, with the highest being 0.21mm
Should I go about finding the appropiate shim sizes, or do I have a larger problem. I made sure my cam shaft cap bolts are proberly torqued and the bearing surface very clean..
Any ideas? thanks
79 SR 650 D2
1979 SR650 D2
