Bigger CC's
- Duck
- e vica na i sau na ga
12 Apr 2007 15:24 #129370
by Duck
Replied by Duck on topic Bigger CC's
wireman wrote:
Yes, but it requires $275 worth of sleeves plus machine work to block and case. At least $400 more than the 100CC smaller kit.
Unless, oh wise wire one, you know of a cheap, easy to find, used/salvage sleeve that may be fitted
I still have those high comp piston with old fashioned iron rings. 76mm, 13.5:1.
Need a block, sleeves, and machine work to use. I can bore the block and case. Will have to take to the machine shop to have the sleeves bored.
BTW: Added up all the $ I've spent on "bikes" over the last 3 years and it's the same as I would have spent on cigarettes if I still smoked....Hows that for incentive for you guys who are trying to quit...
ANOTHER OPTION FOR BIGGER CC's
1)Ebay pistons for GPz1100/KZ1100 maybe $30 incl ship.
2)$99 rings from Z1, only if you can't get pistons with a good set.
3)J or GS1000 head from a junker, $50-$200
4)Roller chain adapter for 'J' head or GS1000 head.
5)pacer for block about $20-$40
6)gaskets???
Post edited by: Duck, at: 2007/04/12 18:47
1197 is a nice semi round number!
6)gaskets???
- wireman
- Visitor
12 Apr 2007 16:18 #129391
by wireman
Replied by wireman on topic Bigger CC's
Duck wrote:
1197 with sleeves is $150.00 more than the 1075 kit without sleeves the machine work and splitting the cases is what gets ya,1075 is definately a good solid motor with a good head and some cams i just like to be armed for battle!wireman wrote:
6)gaskets???<br><br>Post edited by: Duck, at: 2007/04/12 18:47
- School Teacher
14 May 2008 23:39 #213727
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic Bigger CC's
Duck wrote:
am i reading this right you can put a suzuki head on a kz?
6)gaskets???
1980 kz1000G1
- APE Jay
- Banned
- Thank you received: 58
15 May 2008 22:19 #213934
by APE Jay
Replied by APE Jay on topic Bigger CC's
SuperTrey wrote:
Just standard cylinder boring and honing.
www.aperaceparts.com/machining.html
Jay
What kind of machine work is required for the 1075? Case and cylinders? or just the cylinders?
Jay
- APE Jay
- Banned
15 May 2008 22:22 #213935
by APE Jay
Post edited by: Duck, at: 2007/04/12 18:47[/quote]
am i reading this right you can put a suzuki head on a kz?[/quote]
No you can not
No you can not
- School Teacher
15 May 2008 23:38 #213948
by School Teacher
1980 kz1000G1
thanks hadn't heard about that before.
wireman was it a typo?
1980 kz1000G1
