Bigger CC's
09 Apr 2007 11:28 #128121 by SuperTrey
Bigger CC's was created by SuperTrey
I am just about ready for a rebuild on my 78 kz1000 A2. I would like a little more displacement, but I want to keep the stock exhaust and air cleaners. And most importantly i would like to keep it reliable, i commute on it so i want to keep it simple.
What is the next size up kit for the 1000cc engine? 1050?
Thanks!
09 Apr 2007 14:34 #128156 by Sandy
Replied by Sandy on topic Bigger CC's
1075,and then the 1105 from Wiseco.
Most are going with the 1075(I went 1105)and yes,it's still reliable.B)
1977 KZ1000 A-1
09 Apr 2007 16:25 #128202 by brianrae33
Replied by brianrae33 on topic Bigger CC's
hey sandy..did you get bigger sleeves or just bore the stock ones??
1982 kz1000ltd
  • wireman
  • Visitor
09 Apr 2007 20:05 #128303 by wireman
Replied by wireman on topic Bigger CC's
1197 is a nice semi round number!:P
09 Apr 2007 22:06 #128368 by donthekawguy
Replied by donthekawguy on topic Bigger CC's
Go with the 1105 and an oil cooler. You might want to think about some bigger carbs also. At least 28's. The 26's will leave you angry at the world.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
10 Apr 2007 12:14 #128559 by nads.com
Replied by nads.com on topic Bigger CC's
26mm carbs are not too bad, they are smoother than the 28's at idle and mid throttle.
10 Apr 2007 12:52 #128568 by racer54
Replied by racer54 on topic Bigger CC's
The 1105 bore in stock cylinders will leave the cylinder sleeve wall thickness a bit thin. Most go with the 1075 to keep some meat in the cylinder sleeve to help dissapate heat. Have always been told to use 1075 bore in stock 1000 sleeves for this reason for the street. Lots of racers use the 1105 but they are only using them to race so they don't get the heat soak as much either. A 1105 can be run on the street as some do, as mentioned, but the 1075 should be stronger in strength area of sleeve. Or go to bigger sleeves and go 1197 like wireman says. 26mm will give you better response and more pull on bottom end and around town but the 28mm+ would be better for midrange and top end...marginally but better. 1075's love 29 smoothbores though but $$$!
11 Apr 2007 05:53 #128747 by SuperTrey
Replied by SuperTrey on topic Bigger CC's
What kind of machine work is required for the 1075? Case and cylinders? or just the cylinders?
11 Apr 2007 06:04 #128748 by SuperTrey
And where do you find these 1075 kits?
  • wireman
  • Visitor
11 Apr 2007 09:04 #128792 by wireman
just a cylinder bore.but measure your bores 1st to make sure they will clean up at 1075 before spending the money.ape sells wiseco pistons,z1 might have them also not sure;)
12 Apr 2007 14:51 #129343 by APE Jay
Replied by APE Jay on topic Bigger CC's
The 1075 does nicely in stock 1000 sleeves, staying nice and round. 1105s in stock sleeves are too thin and can not hold shape. A sealed up 1075 will make more power than a leaking 1105.
We try to discourage people from doing the 1105s.
1075 is a simple bore and hone.
Jay
Post edited by: steell, at: 2007/04/12 18:08
12 Apr 2007 15:09 #129356 by steell
Replied by steell on topic Bigger CC's
Allow me :)
Here are the pistons;
kzzone.com/pistons.html
