have you ever seen this??
- Jay_G
09 Apr 2007 03:53
Well have you?
was having starter clutch problems on my 750, so i pulled it apart today and found this, plus 2 of the 3 bolts were loose.
i think it could have ended in tears.
Post edited by: steell, at: 2007/04/09 08:32
- flht1997
Re: have you ever seen this??
09 Apr 2007 04:45
yup, i have been there, except mine had two cracks in it
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- cjhansen2
09 Apr 2007 06:43
Kz750 starter clutches are the same as KZ400 ones. They were not designed to spin over a 750. Fix it, and it will break again. Get good at kick starting the bike...just watch your shins.
- Klaus42
09 Apr 2007 09:12
How much of a PITA would it be to convert/add a kickstarter to my '81 750 LTD? Just from the sound of the starter engage/disengage, I expect to find trouble...:dry:
- Sixgun
09 Apr 2007 10:33
Ouch! Mine just sheared the bolts out of it. There's a scrapyard here in Columbus that has the clutch available, but I'm not sure how much. CJhansen2 is right on with the 400. Sucks that they got rid of the kick start in later models. I kick mine when it's cold and only use the electric once it's warmed up.
Here's the link to that scrapyard. They can be a bit pricy, but I've always found what I needed.
www.ricepaddymotorcycles.com/
78 KZ750 B3
81 XS650SH
80 XS650G
81 XS650SH
80 XS650G
- Jay_G
09 Apr 2007 12:35
im starting to think the reason it has the sheet steel sheild around the actual solid piece is because kawasaki was expecting it to break. because it kept it all in there.
