wtf?
  • customkzft
  • customkzft's Avatar Topic Author
wtf?
08 Apr 2007 11:52
#127722
OK, Im stumped!
So I've posted a few questions lately and now I'm stumped for good.
I thought I was having a timing problem as to why my 1 and 4 cylinders were not firing, so i took the top end appart and double checked the timing and it looked fine, the cams were right on and 1 and 4 pistons were at TDC.
Now I'm trying to start it but nothing! plenty of gas and spark. I guess checking compression would be my next step.?.?.?
I've read alot of post about ignition timing, Is this something I can try? thanx guys and happy easter!
Post edited by: customkzft, at: 2007/04/08 14:55
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: wtf?
08 Apr 2007 12:00
#127724
I think I remember something about you having had this engine apart recently. Am I correct? If you would keep posting in whatever thread you previously did we would have the benefit of knowing what you've already been through.
But to start in the beginning. If you're having troubles with 1&4 look to your coils and points, if you bike is so equipped. An easy first step is to swap the 2/3 coil for the 1/4 coil and see if the problem moves. Is it possible that you have the 1/4 coil firing when it should be the 2/3 coil and versa visa?
KZCSI
Post edited by: KZCSI, at: 2007/04/08 15:05
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • customkzft
Re: wtf?
08 Apr 2007 12:05
#127726
I've done all that, I'm getting plenty of spark and fuel just not firing! like it's not timed, or it's flodded, It was running but only on 2 and 3 and then it would fire on all 4 then it would quit and only fire on 1 and 4, it's crazy, bow it checked the timing and everything looks good but it's not starting at all.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: wtf?
08 Apr 2007 12:09
#127729
Is it possible that in "doing all that" you've cross wired the coils? Do you have a wiring diagram? Are you sure that the 1/4 coil is the one that's firing when either 1 or 4 is at top dead center?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • customkzft
Re: wtf?
08 Apr 2007 12:14
#127731
are you talking about the actual plug wires or coil possitive and negative wires? because I am possitive that the plug wires are right now do the coil wires (black and red) have specific coils to go to? I thought they are just constant power to the coils.
  • BSKZ650
  • BSKZ650's Avatar
Re: wtf?
08 Apr 2007 12:56
#127745
what bike are you working on, maybe its the points and condensers if yours has them
77 ltd1000, current rider
76 kz900, just waiting
  • customkzft
Re: wtf?
08 Apr 2007 13:01
#127747
96 KZ1000 P
  • AR15Ron
  • AR15Ron's Avatar
Re: wtf?
08 Apr 2007 13:31
#127754
Make sure your plug wires are going to the right plugs first. On my 1978 1000 it goes: Left coil (if you are sitting on the bike) 1+4, right coil 2+3. If you have them wrong like 1+2 3+4 it wont run. Cylanders are 1,2,3,4 left to right.
Ron
  • customkzft
Re: wtf?
08 Apr 2007 13:47
#127758
yes the wires are going to the right cylinders, I have taken it appart many times but this is the first time it will not start.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: wtf?
08 Apr 2007 15:26
#127795
Hey customkzft,
I'm speaking about the primary wires (the little ones). If your bike is a 96 I'm sure it has electronic ignition. But still each coil gets a specific signal to fire when it's time is right. It would be relatively easy to hook the coils up in reverse and have the 2/3 coil fire when the 1/4 coil is supposed to. You would still see spark at all the plugs but you would never be able to tell that the spark was happening at the wrong time for every cylinder.
It's just something to check. Actually I would expect that with the coil primaries swapped it'd be backfiring through both the carbs and the exhaust. In any case, it wouldn't run at all and that's where you are!
KZCSI
Post edited by: KZCSI, at: 2007/04/08 18:27
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • customkzft
Re: wtf?
08 Apr 2007 16:45
#127815
Thanx for all the help, I do infact know i have the wires switched I didn't think it mattered to switch the wires, thanx ill check tonight and let you know.
  • customkzft
Re: wtf?
09 Apr 2007 18:56
#128257
Well what do you know, I got home last night switched the coil wires and it started up! thanx again for another great reponse from you guys!
