differences 4cyl 650 to 4cyl 750
  • SLEEPER650
  • SLEEPER650's Avatar Topic Author
08 Apr 2007 11:18
#127712
what are the differences from a 650 to 750 4cyl? is it just the bore size or is there a stroke difference? i know the rods are the same.
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
  • cottoncandyninja
  • cottoncandyninja's Avatar
Re: differences 4cyl 650 to 4cyl 750
08 Apr 2007 11:50
#127720
i have a 750 and was always under the impression the bottom end was different. at the same time i dont know a whole lot about 650s either.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
08 Apr 2007 11:55
#127723
Early 650s used a bicycle style cam chain, but the later models used the hyvo chain like the 750s. The major differences were a smaller bore and slightly smaller valves. A 750 top end will bolt onto a later model 650 bottom easily, and will bolt onto an early model 650, but you have to keep the cam chain sprockets and idler sprocket from the 650.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
08 Apr 2007 13:53
#127764
Welcome Sleeper650.
750-stroke=54mm, bore=66mm, CC=738, Comp Ratio=9.0:1
650-stroke=54mm, bore=62mm, CC=652, Comp Ratio=9.5:1 (LTD 9.0:1)
Corrected. :whistle:
Post edited by: rstnick, at: 2007/04/09 10:40
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • SLEEPER650
08 Apr 2007 14:28
#127774
well this is what i have i have two sets of jugs a 650 jug that mesures2.440inch and a 750 jug that mesures 2.600inch if what your saying is correct then the 750 is .160 over already.
78 650sr my baby
82 kz1100
  • agawam
  • agawam's Avatar
08 Apr 2007 18:59
#127863
he has the B&S backwards should be 54mm stroke for both and 62mm bore for 650 and 66mm bore for the 750
  • SLEEPER650
09 Apr 2007 02:37
#128018
thank you that sounds better. yesterday i picked ut an 83gpz 750 for 15.50 . so im on my way to an 810
78 650sr my baby
82 kz1100
  • H1Vindicator
  • H1Vindicator's Avatar
Re: ----
09 Apr 2007 06:17 - 20 Feb 2013 18:47
#128044
Last edit: 20 Feb 2013 18:47 by H1Vindicator.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
09 Apr 2007 07:39
#128073
Ooops, sorry about that. :whistle: :blush:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • SLEEPER650
09 Apr 2007 18:06
#128236
no harm done
78 650sr my baby
82 kz1100
  • guitargeek
09 Apr 2007 20:20
#128313
Am I to understand that you purchased a 1983 GPz750 for fifteen dollars and fifty cents?
Son of a...
  • SLEEPER650
10 Apr 2007 15:01
#128595
you know the auction site
78 650sr my baby
82 kz1100
