Oil System Parts...
- hobodan
Oil System Parts...
07 Apr 2007 18:59
Hello again everyone!
I am trying to get my engine to point where i can get it started. It is a 1977 KZ650 and it has been sitting for a long time. I am missing some parts that belong to the oil pan and i was wondering if any of you know where i can get the parts.
I have found a couple of them on the Z1 website, but not quite everything.
Here is the diagram from the kawasaki parts site:
Here is the list of stuff it needs:
18 - 2 "0" RINGs,90MM
19 - the oil pan gasket.
22 - The oil plug, but i can probably get a bolt that fits...
27 - SHIM-KICK SHAFT?
28 - SPRING,OIL FILTER
29 - PLATE,OIL FILTER
30 - the oil filter cover.
31 - the oil filter bolt assembly.
I can probably get the gaskets and o rings from the dealership, but i dont know if they still carry anything that old!
Any help you guys can give would be great! I really appreciate it!
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
- RetroRiceRocketRider
Re: Oil System Parts...
07 Apr 2007 20:34
18 - 90mm o-rings...STP and Fram oil filters come with the o-rings for both the filter cover and filter bolt.
So I'd suggest just hitting up your local auto parts (Kragen, Auto Zone, Checkers, etc) and stocking up on a few of those filters (about $4 each) and swip the o-rings from them. FWIW, those o-rings don't need to be replaced every time the filter is changed.
Beats spending about $6+ for the 90mm o-ring from the dealer, and you'll have a supply of oil filters for later use as a bonus.
19 - Oil pan gasket...check eBay, as they show up on there for about $10+ shipping. Expand your search on eBay, as that gasket also fits all years of the GPz750 and ZR750 Zephyr, and I believe all years/models of the KZ750's, as well.
27 - SHIM-KICK SHAFT?....That "shim" is basically just a thin washer, it keeps the spring (28) from pushing up into the filter and preventing it from filtering properly.
You can try your luck on eBay for these as well.
If you want though, I have extras of all of them that are yours for whatever shipping will cost.
Post edited by: RetroRiceRocketRider, at: 2007/04/07 23:35
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
