valve shim check
- ronjones
valve shim check
06 Apr 2007 14:37
Got all my shims today:), Z1's service is great. Can I just lay my cams back in, to recheck my clearances, before putting it back together? I just want to make sure all my measurments were correct and I didn't mess up the shim placement.
Thanks
RonJ
Thanks
RonJ
- ronjones
Re: valve shim check
07 Apr 2007 10:00
Wow, 42 views and no one has an opinion if I can get a semi accurate valve clearance measurment, by just laying the cams in place, w/o doing the full install. I'm gonna give it a try and see what kind of measuement I get. Hopefully it will be close to what I'm expecting.
- Klaus42
07 Apr 2007 10:04
OK, you want opinion, here it is: No way can you get an *accurate* measurement of such minute tolerances without properly installing and torqueing to spec your camshafts, first.
Now, mind you, this is *merely* my utterly unfounded, inexperienced *opinion* !
- ronjones
07 Apr 2007 10:43
Klaus42 wrote:
Ron
Well, Klaus...you are absolutly correct. Didn't work, the cam lobe on the opposite end kept the cam elevated. Thanks for the reply:)OK, you want opinion, here it is: No way can you get an *accurate* measurement of such minute tolerances without properly installing and torqueing to spec your camshafts, first.
Ron
