new cylinder bores..
  • brianrae33
  • brianrae33's Avatar Topic Author
06 Apr 2007 06:44
#126986
just put my new 1075 kit in and it would only fire on the 3 and 4 cylinders...turn out a coil wire was grounding to the frame...now..i had it running for about a minute or two...i'm hoping that fuel dumping into the cylinders didn't wreck my rings...fires great now but smokes alittle...although i did have too much oil in it...drained it and refilled properly...could the smoke just be residual??will be doing a compression test soon as well..
1982 kz1000ltd
  • BSKZ650
  • BSKZ650's Avatar
Re: new cylinder bores..
06 Apr 2007 06:55
#126991
you need to ride it like you stole it to break it in, then do a compression check, if you try to do it now its going to show low
77 ltd1000, current rider
76 kz900, just waiting
  • wireman
  • wireman's Avatar
06 Apr 2007 07:41
#127003
put a few hundred miles on it before worrying about compression test.do an oil change at around 500 miles since you already did it once,then again at around 3000
  • racer54
  • racer54's Avatar
06 Apr 2007 13:30
#127115
Did you oil the cylinders when putting it on? I usually do and it will smoke a little til it burns off the excess oil in the cylinder, but it will clear up. Some guys oil cylinders before sliding pistons in and some don't...both ways have their good points, but I oil mine and get smoke at first but have always cleaned out and ran fine. I wouldn't worry about it til you give it time to settle in and give the rings time to seat. I once had rings that didn't seat and trust me....you will know.
  • Kiwiz
  • Kiwiz's Avatar
06 Apr 2007 14:49
#127141
I used a little oil putting my new Wiseco into my J. I think the critical thing is the run in for the first few hundred miles. Give it heaps to allow the rings to bed in properly. My greatest problem was trying to do so without running foul of the law. Dawn runs on a major piece of steep freeway. Then an oil change.Never botherred to check compression. It goes , doesnt smoke and thats enough for me!
  • brianrae33
07 Apr 2007 06:26
#127292
thanx all for the replies...it just seems to huff white smoke after it's been running awhile...found some carbon fouled plugs as well...think i may have a coil wiring issue...plan on doing the old wiredgeorge method in the next couple of days....haven't got to ride her yet...just started her up and let it idle alittle..hopefully the coil mod and a good rip up and down the freeway will clear things up..
1982 kz1000ltd
  • wireman
  • wireman's Avatar
07 Apr 2007 08:12
#127317
take her out and ride it,idling will just heat her up and let cylinders wash down,need to take it out and run it hard to seat the rings;)
