Question on replacing Cam Chain KZ1100
  • FloridaBiker
  • FloridaBiker's Avatar Topic Author
30 Mar 2007 11:49
#124943
I've been assured I can replace pistons with the engine still in the bike.
Can I do the same with the cam chain?
Does it have a master link?
Bike is a '82 KZ1100 shaft
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Question on replacing Cam Chain KZ1100
30 Mar 2007 11:58
#124946
You will have to buy the correct length cam chain, then split it, and buy a master link. You will have to split the old cam chain in place, use the master link to attach to the new cam chain (don't put on the side plate and pull vertically so the master link can't fall out), pull the new cam chain through, remove the old cam chain, then finish attaching the side plate to the master link to both ends of the new cam chain.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • FloridaBiker
30 Mar 2007 15:17
#125004
You guys are great!
It is nice to find a forum that is useful, and not over-run with distractions.
Thanks for the help.
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
30 Mar 2007 16:36
#125025
Just for giggles;
why are you replacing the cam chain? Have you actually measured it, or were you just getting a lot of cam chain rattle?
When I tore mine down one of my concerns was a lot of rattle when it was parked 17 years ago. The cam chain tensioner/guide blocks were all worn deeper than spec(front and rear about 1/4", top not as bad) so I wondered about the chain. Since it's a Hy-Vo chain, you do compromise its strength by splitting a link and using a master, so I went ahead and tore it down. Result: New chain and old chain are almost identical lengths!:pinch:
Got ahold of a retired Kaw mechanic, he said he wasn't surprised. Said those Hy-Vo's wore very well, but really seemed to wear out the cam blocks. Duh. He remembered seeing a memo when the J's came out with the Hy-Vo chain that said that the factory was trying to move the wear from the chain to the tensioners, so it would be easier to replace. So you might want to double-check your cam chain stretch. It might just need tensioner blocks.
Oh, and what's this about not being over-run with distractions?
The Easter Bunny Distraction
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • FloridaBiker
30 Mar 2007 17:12
#125033
pstrbrc wrote:
Just for giggles;
Basically, I screwed up. With the tensioner removed for replacement the bike was on the center stand, IN GEAR. I needed to move the bike. The sudden lurch as it came off the center stand put a kink in the chain.
Oh, I am talking about the lack of flamers and similar ilk.
