Can I change pistons without removing engine?
  • FloridaBiker
  • FloridaBiker's Avatar Topic Author
30 Mar 2007 04:46
#124844
The bike is a '82 KZ1100 shaft.
Is it necessary to remove the engine to replace the cylinders and pistons?
Post edited by: FloridaBiker, at: 2007/03/30 18:14
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Can I change pistons without emoving engine?
30 Mar 2007 05:48
#124852
The engine doesn't need to be out of the bike to remove/replace the cylinders and pistons, but you would have more "working room" with it out.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • Mark Wing
  • Mark Wing's Avatar
30 Mar 2007 07:31
#124872
Like R4 said. I always wait to put the top end on after the engina is in the frame on a rebuild to make it lighter to put the block in the frame.
Mark
Yorba Linda Cal.
  • themachine
  • themachine's Avatar
30 Mar 2007 09:08
#124889
Mark
takes two midsized guys to rip motor out.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • Mark Wing
30 Mar 2007 13:07
#124971
With the top end removed I've never needed help getting it out or back in. Don't know what to tell you.
Mark
Yorba Linda Cal.
  • apeman
  • apeman's Avatar
30 Mar 2007 13:37
#124990
Mark
You da Man, Mark!!
I about busted a gut removing the bottom half of the engine on my project bike. Of course, I wasn't doing it right, and was trying to get it out without removing the airbox. I kept getting hung up, then losing my strength, then slipping on the floor (covered in oil), then catching on the wire harness (shoulda taken that off too). If I did it the right way, it wouldn't have been too bad.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • arobsum
  • arobsum's Avatar
30 Mar 2007 16:52
#125028
my buddy would lay the frame on its side over the engine...slip the bolts in then stand it up...i thought he was crazy.
