head bolts and wrist pins
  • themachine
  • themachine's Avatar Topic Author
28 Mar 2007 19:12
#124456
i'm getting the 1170cc 10.5:1 pistons for my bike and i was curious as to if i could reuse my headbolts and wrist pins, anyone care to chime in.
i'm getting this from ape, i also want to get a set of street/race springs, do i need their spring retainers or would these work just fine.
its a 1000J
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • wireman
  • wireman's Avatar
Re: head bolts and wrist pins
28 Mar 2007 19:25
#124463
piston kit should come with wristpins and clips.match your valvetrain to your cams,if your cams need shim under buckets you need to change your retainers;)
  • themachine
29 Mar 2007 03:05
#124519
i'm not changing the cams yet, i plan to redo the head wit bigger valves, shim under buckets and all the good stuff next year.
  • BSKZ650
  • BSKZ650's Avatar
29 Mar 2007 04:44
#124527
I would call Jay, he knows the kit you are getting and I am sure he would know what the weak points are going to be
77 ltd1000, current rider
76 kz900, just waiting
  • wiredgeorge
  • wiredgeorge's Avatar
29 Mar 2007 05:36
#124544
You have three choices. Re-use your stock head nuts. This will work fine especially if you re-anneal the copper washers on the outer studs. You can buy aftermarket nuts; K&L sells them. I have not had good luck using these as they are somewhat smaller diameter compared to the stockers and tend to allow leaks from the oil journals (outside studs). You can buy APE head nuts which are stronger than the stockers and shaped the same. These will work fine as well, I suspect but cost quite a bit as memory serves.
  • APE Jay
  • APE Jay's Avatar
31 Mar 2007 11:22
#125196
Any new piston kit that you get from us will come with new pins.
Just looked in the new K&L book, and they don't have head nuts. All I could find were regular flange nuts. We are the only ones that make a head nut that is stronger than oem.
Jay
Post edited by: APE Jay, at: 2007/03/31 14:28
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
31 Mar 2007 12:36
#125214
Jay-
Are those nuts stamped(forged) or turned?
-Duck
Post edited by: Duck, at: 2007/03/31 18:54
  • APE Jay
  • APE Jay's Avatar
01 Apr 2007 15:06
#125617
Ours are CNC machined from billet bar stock then heat treated.
Jay
