crankshaft bushings
- cottoncandyninja
Re: crankshaft bushings
18 Apr 2007 12:19
one thing leads to another. i tried to get some crankshaft oil seals from ronayers and found out one of the two is discontinued. besides asking jeff saunders if he has any lying around (though i think that is fruitless due to the fact i know he orders some parts from kawasaki themselves), does anyone have any ideas as to wear i can get FRESH, NEW crankshaft oil seals from? the parts numbers for these little seals are 92050-080 and 92050-081. just two seals on either end of the crankshaft. thats all. i need em. i need resources. ones discontinued. theres gotta be a huge old motorcycle warehouse with a dusty plastic bag with two fresh seals in it. gotta be. or else ill just wither up and die. im out.
- BSKZ650
18 Apr 2007 13:27
why wouldnt those seals be in a full gasket set
77 ltd1000, current rider
76 kz900, just waiting
- steell
18 Apr 2007 13:39
BSKZ650 wrote:
One seal appears to be 22mm x 39mm x 7mm
The other appears to be 25mm x 39mm x 7mm
92050-080 seal number HSCY22397 appears to be the left side.
92050-081 seal number ,HSCY25397 appears to be the right side, and it's also used on a Zx600 (and maybe a 550).
You might try cross referencing the seal numbers at a bearing supply.
Because oil seals are not included in the gasket set for the 750 four motors.why wouldnt those seals be in a full gasket set
