Camshafts strangeness...
  • tuxedotito
  • tuxedotito's Avatar
Re: Camshafts strangeness...
10 Apr 2007 16:30
#128612
If you were measuring in inches of course:blink: :whistle:
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
  • wireman
  • wireman's Avatar
10 Apr 2007 16:53
#128619
BSKZ650 wrote:
bearings look good to me, I would take a green scotch brite pad, some light oil, and a light buff, very light buff, just to clean off any scratches that may be on them , put them back in and reinstall the cams, replace the idler, check the valve lash, and run it
:blink: :ohmy: :unsure: :S :huh: :dry: bad bearing,bad bearing!eek somebodt aint been chaging their oil!;)
Post edited by: wireman, at: 2007/04/10 19:54
  • BSKZ650
  • BSKZ650's Avatar
10 Apr 2007 18:25
#128635
well they aint perfect, but they will work, they are not down to brass, there is still a lot of life left in them, yes there are some marks on them, but the scotch brite and oil will shine them right back up.
But as wireman says they are not the best, and if you want you could replace them,'
bow down to the wireman god,or he may sick the road runner on me
77 ltd1000, current rider
76 kz900, just waiting
  • trippivot
  • trippivot's Avatar
10 Apr 2007 18:31
#128639
send the measurements to NASA I'd just reassemble and torque it up. Get fresh oil and ride it sherman!!
Peabody transmitting... over and out
  • Conti
  • Conti's Avatar Topic Author
10 Apr 2007 23:27
#128715
tuxedotito wrote:
The scale on the plastigage reads (.038), not (0.38)
Looks to be within specification?? 0.38 is almost a half-inch!
Regards...
:blink: Erm...
Well, ok, it must be said in my defence that it was the first time I used plastigage. :laugh:
Well... :blush:
Thanks for noticing it !!! :cheer:
  • wiredgeorge
  • wiredgeorge's Avatar
11 Apr 2007 05:13
#128729
The cams are fine. The bearings are fine. Assemble. Ride!
  • wireman
  • wireman's Avatar
11 Apr 2007 06:39
#128756
they are usable but ya can see were the oil hasnt been changed reguarly and those little flakes missing out of bearings bear a striking resemblance to the little flakes on the cam bearing surface which will grind their way into the bearing if they are not removed;)
