Ahhhhh Ooooops
  • K-man
  • K-man's Avatar Topic Author
Ahhhhh Ooooops
25 Mar 2007 15:16
#123372
Hypothetically speaking let say you knew someone who was cleaning the carbon off the top of a piston with a buffing wheel on a bench grinder and the piston shot out of his hand and cracked on the ground. Could that person just buy 1 new stock piston and fit them all with new rings or do all 4 have to be replaced with with a cylinder bore.
  • wireman
  • wireman's Avatar
Re: Ahhhhh Ooooops
25 Mar 2007 15:27
#123374
have ya been working around tganek again?:P what kind of motor is it?
  • K-man
Re: Ahhhhh Ooooops
25 Mar 2007 15:50
#123378
Ha ha ha, I think I need more ventalation in my garage, I must be breathing in too many fumes. It is a 1015cc A1 motor.
  • BSKZ650
  • BSKZ650's Avatar
Re: Ahhhhh Ooooops
25 Mar 2007 15:58
#123380
shlould be able to buy one of the same pistons ,ie mfg, comp ratio, it should work, but if I went to all the trouble to take it that far aprt I would replace all the rings, providing things do not have too much wear
77 ltd1000, current rider
76 kz900, just waiting
  • wireman
  • wireman's Avatar
Re: Ahhhhh Ooooops
25 Mar 2007 15:58
#123381
you could get away with just one piston,only trick would be finding a piston that was really close to same bore dimensions of what you took out because they all wear a little differant depending on how many miles it has on it and how well it was cared for ;) might be time to step up to that 1385 and bigblock on APES website :evil: okay maybe just the 1075 kit,baby steps are best they tell me!:P
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Ahhhhh Ooooops
25 Mar 2007 16:07
#123385
I have a complete set of pistons(with wristpins) in very nice shape...with 2 sets of rings...if You're interested.
I can email You some pics if You are...
1977 KZ1000 A-1
  • Pterosaur
  • Pterosaur's Avatar
Re: Ahhhhh Ooooops
25 Mar 2007 16:07
#123386
What WiredOOd said, plus...
Hopefully, you've got the pistons numbered according to which bore they came out of - 1 - 2 - 3 and ooops, let's say, and once you get the right replacement piston, have them weighed on a good scale and match the weights on 1 and oops as closely as possible. Doing the same on 2 - 3 wouldn't hurt either.
Hone the bores within tolerances, re-ring with a fresh set, and you're there. ;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: Ahhhhh Ooooops
25 Mar 2007 18:43
#123436
I suppose aside from the siren call of carbon less crowns, the pistons and rings were OK? If the rings are still OK, transfer them to a good one and put her back together.
If bores are glazed, unlikely but if so they'll look like glass, you might want to go over them with some emery paper or fine hone.
-Duck
  • K-man
Re: Ahhhhh Ooooops
27 Mar 2007 19:52
#124143
thanks for the suggestions, I think I will go with the 1 piston, new rings and a hone job route. Just out of curiosity how much would a guy have to spend for a big bore kit.
  • wireman
  • wireman's Avatar
Re: Ahhhhh Ooooops
27 Mar 2007 20:03
#124153
define bigbore!:P check APES website
  • AR15Ron
  • AR15Ron's Avatar
Re: Ahhhhh Ooooops
27 Mar 2007 22:54
#124198
this might be worth watching, or not IDK.
cgi.ebay.com/ebaymotors/Dragbike-kz1000-...QQrdZ1QQcmdZViewItem
