transmision leak and malfunction
- MT 81 kz750
25 Mar 2007 14:33
I have an 81 kz750 four that has a bad leak coming off the front sprocket right out of the transmision. I would assume that it has a oil seal that needs to be replaced. My question is 1, what do they call that seal and 2, do I have to replace the seal around the shifter.
Also My transmission only clicks into 1st gear and Neutral. It won't go up any higher. I figure while I am fixing the seals I can take a look at the tranny. Are the tranny's complicated or is it something I can fix.
- wireman
Re: transmision leak and malfunction
25 Mar 2007 15:31
it wont shift into 2nd gear unless back wheel is moving;)
- MT 81 kz750
25 Mar 2007 17:13
Awesome!well I guess when you are starting out you run the risk of asking dumb questions. Any ideas on the seals.
I really have to get myself a shop manual.
Dan
Post edited by: MT 81 kz750, at: 2007/03/25 20:14
Dan
- wireman
25 Mar 2007 17:55
ive never worked on a 750 but im sure somebodys got an idea;)
- RetroRiceRocketRider
25 Mar 2007 19:48
There are actually 3 seals on the mission (transmission) cover, and it'd be a good idea to replace them all IMO.
Output shaft seal (Kawi p/n 92050-024)
Shift shaft seal (Kawi p/n 92051-005)
Clutch puch rod seal (Kawi p/n 92049-1017)
Mission cover gasket (Kawi p/n 11060-1056)
The sprocket cover has two seals in it (p/n 92051-005)where the shift shaft comes through it, but you shouldn't need to replace them unless they're damaged.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
