adjusting a manual cam chain adjuster on my 74 Z1 900
- oldkaws4ever
- Have no regrets...... You only live once.
22 Mar 2007 21:23
My Z1 juststarted making a little cam chain noise. does anybody know how to adjust the manual cam chain adjuster, should i turn the 17mm nut under the points cover to 1,4 or 2,3 and how do i know when the adjuster is tight enough
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- kzwolfsr
Re: adjusting a manual cam chain adjuster on my 74 Z1 900
23 Mar 2007 17:16
Well you can turn the ignition nut if you want and go through the specific steps which will give you some relief. When I tighten my chain with my manual tensioner I just loosen the locking nut and turn the bolt by hand to see what slack there is then I take a wrench and turn it like a half turn. Do half turns and start the bike and listen for the chain noise.
Original man of the Caribbean
