exhaust stud
  • brawnyrebel
  • brawnyrebel's Avatar Topic Author
exhaust stud
21 Mar 2007 20:21
#122402
I am in need of a 6mm exhaust stud. z1 is out. anyone have one laying around?
Re: exhaust stud
21 Mar 2007 20:34
#122405
Might try Redline has 6mm exhaust stud listed for $3.85 :)
Redline Stud
Post edited by: Patton, at: 2007/03/21 23:35
  • reborn650
  • reborn650's Avatar
Re: exhaust stud
21 Mar 2007 21:51
#122432
O.K. this one was handed to us on a platter.
When I am tired after a good shagging would that qualify as an exhausted stud...oh sorry, I misread the question. You are inquiring about an exhaust stud:)
Check with Jeff@ Z1enterprises.com
-1998 Jeep TJ Wrangler 4.0...
  • brawnyrebel
Re: exhaust stud
22 Mar 2007 14:32
#122614
If thats you in your avitar i would say you would be exhausted
  • Bluemeanie
  • Bluemeanie's Avatar
Re: exhaust stud
22 Mar 2007 20:17
#122730
Run down to your local Home Depot, Lowes, hardware store, what ever and get a 6mm bolt of the right length or longer. Cut the head off leaving one 6mm exhaust stud! Either run a nut or if you have one a thread chaser over the cut end. Price of this project?, probably less than a buck and about 10 minutes work!
Post edited by: Bluemeanie, at: 2007/03/22 23:20
Re: exhaust stud
22 Mar 2007 20:42
#122738
Note of caution ---
Recall reading in a previous post that some of the stud holes end up very close to an oil channel in the head.
If using a tap to clean up the threads before screwing in the new stud (or doing drilling or any other work inside the thread hole), be careful not to cut on through the deep end and into an oil channel.
Just FYI :)
  • reborn650
Re: exhaust stud
22 Mar 2007 20:47
#122744
Nah, just a funny pic referring to riding a hog-harley:)
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: exhaust stud
23 Mar 2007 17:58
#122928
Bluemeanie wrote:
Run down to your local Home Depot, Lowes, hardware store, what ever and get a 6mm bolt of the right length or longer. Cut the head off leaving one 6mm exhaust stud! Either run a nut or if you have one a thread chaser over the cut end. Price of this project?, probably less than a buck and about 10 minutes work!<br><br>Post edited by: Bluemeanie, at: 2007/03/22 23:20
Not a good idea. Exhaust studs have slightly different threads on the two ends. The end that goes into the head is larger in diameter to bite into the head material. If you use a bolt with the head chopped off, the stud wll be slighly undersized and will likely come loose or worse strip the thread out of the head.
To see which end is which, you cannot thread a nut on the larger end of the stud.
Post edited by: Jeff.Saunders, at: 2007/03/23 20:59
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • wiredgeorge
  • wiredgeorge's Avatar
Re: exhaust stud
23 Mar 2007 18:03
#122932
6mm studs are readily available in most autoparts stores. I have bought both 6 and 8mm studs through Maryland Metric.
  • Bluemeanie
Re: exhaust stud
24 Mar 2007 08:36
#123077
Thanks Jeff. I've never done what I suggested, it just sounded good in theory. I can be KZMoron at times, learn a lot here.B) Thanks for the info...
  • kzwolfsr
  • kzwolfsr's Avatar
Re: exhaust stud
24 Mar 2007 14:38
#123148
I would just buy a bolt from the harware store and screw that sucker in there.
Original man of the Caribbean
