Bad News(?) No 3 Cyl
- JimatMilkyWay
21 Mar 2007 13:06
Well guys I am the proud owner of a brand new, Deelux, Pro-fessional compression test gauge. I only did a preliminary, dry compression test late last night. I have not had a chance to investigate any further yet, concerning other tests or consequences of what I have done. Compression, after ten cycles on each cylinder is:
1) 135 lb
2) 124 lb
3) 89 lb
4) 129 lb
Oh, Dear!
1) 135 lb
2) 124 lb
3) 89 lb
4) 129 lb
Oh, Dear!
- BSKZ650
Re: Bad News(?) No 3 Cyl
21 Mar 2007 16:02
check the valves, may have a tight one
77 ltd1000, current rider
76 kz900, just waiting
- JimatMilkyWay
21 Mar 2007 16:51
BSKZ650 wrote:
I deduced that a single cylinder valve issue is more fleasible than a single cylinder ring issue. I must head back off to work at 9P, so will not get to do anything further today.
I just bought the gauge and, while I have read over proper procedure for performing compression tests in the KZ info section, I have not actually studied it.
I will keep my fingers and toes crossed if you will.:laugh:
BTW, do I need to pick up some gaskets before I crack the valve covers?
Post edited by: JimatMilkyWay, at: 2007/03/21 19:55
Thanks BSKZ650, and I hope,,,err I KNOW you are right. I thought about it a bit today, and just from sheer genius logic,check the valves, may have a tight one
- AR15Ron
21 Mar 2007 22:09
you can likely re-use the old gasket if you dont break it taking the cover off
- loudhvx
21 Mar 2007 23:04
Just making sure... you had the throttle wide open with the choke off, right?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
