What cams swap in a 1981 ltd 750????
- tbax
20 Mar 2007 22:53
I have read a few past posts talking about swaping gpz cams into kz 750 heads. I was under the impression that the 1983 gpz model had a different head and cylinder setup than 80 81 82 kz/ltd models. I want to put these hotter cams in but I want to make sure I buy the right cams before I spend my hard-earned ebay money. I'm planning on building a 810 with this 1981 ltd motor I have. All said and done right, do you think it will keep up with a stock 900??? Thanks.
- 77KZ650
Re: What cams swap in a 1981 ltd 750????
20 Mar 2007 23:24
if you get carbs and exhaust to go with the cams and pistons you should be able to match a stock 1000. ask reborn650;)
07 MDP Rookie of the Year
- steell
21 Mar 2007 04:09
GPz750 head through 85 will bolt on, as will the cylinder block, the only problem is the 83-85 gpZ750 has no provision for a tach drive, and the 83-85 GPz750 cam has no tach drive gear.
- tbax
21 Mar 2007 07:21
Is the 81 82 gpz or kz 750 head basically the same head as far as flow characteristics and cam grind as the 83-85 gpz head??? If there isn't any difference I guess I'll try to keep my tach.
- steell
21 Mar 2007 07:57
83-85 GPz750 cam has the most lift and duration of any stock 750 cams.
1980 KZ750 head has the smallest combustion chambers of the 750's, and just needs a little porting to outflow the 83-85 GPz750 head.
