Auto cam tensioner
- Kzbatty
Auto cam tensioner
19 Mar 2007 17:08
Is there any way to manually tighten the cam chain if you have an auto tensioner, short of cracking the case and putting on a new chain, or pinning a new one in? I have a loose chain noise and I have consulted my manual, but there isn't anything in there about tightening it up, just removal and installation.
- 77_650B1
Re: Auto cam tensioner
19 Mar 2007 17:18
you can reset it if it says how in your manual, i know it does in some. otherwise no dice, get an APE manual.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Bluemeanie
19 Mar 2007 20:54
Z1 Enterprises has a manual cam chain tensioner for my bike, I'm sure for your's too...
- Kzbatty
20 Mar 2007 09:33
I checked with Z1 I didn't see one listed, so I inquired if they have one for my '83 KZ1100-L LTD.
What about replacing the chain? I have read in the archives that splitting the chain is not really advisable. Is that still the general consensus?
- FloridaBiker
20 Mar 2007 12:22
Z1 does does have a tensioner for your bike.
www.z1enterprises.com/detail.aspx?ID=371
I have it on my '82 KZ1100 and its great!
- wiredgeorge
20 Mar 2007 12:22
You can see the manual tension on the APE website... it is for the J motor. The tensioner is pretty much the same as the one for the 903/1015 but the mount part is a bit different shape.
- FloridaBiker
20 Mar 2007 12:22
