valve lifter stuck!
- Joe
valve lifter stuck!
18 Mar 2007 14:11
ok right I have:
1. checked clearance for valves
a. number 4 exaust valve has a clearance of something undern .04. I don't have a ssmall enough gauge.
b. I pulled the lifters out w/ a suction cup, but when i got to the #4 exaust its stuck.
any inputs?
Joe
Post edited by: Joe, at: 2007/03/18 17:11
any inputs?
Joe
- Joe
Re: valve lifter stuck!
18 Mar 2007 14:15
also the clearances were as follows:
Exaust
1 .09
2 ..1
3 .2
4 something under .04
Intake
5 .1
6 .07
7 .1
8 .09
Exaust
1 .09
2 ..1
3 .2
Intake
5 .1
6 .07
7 .1
8 .09
- RedneckSamurai
18 Mar 2007 14:41
Does it move at all? I once thought athe number four was jammed somehow but it was just hitting the cam end cap:whistle:
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
1976 KZ900ltd
1976 KZ900 A4
- Joe
18 Mar 2007 14:59
its stuck, it not hittin the end cap. i guess i'm gonna have to lift the whole casing off.
18 Mar 2007 15:38
Joe wrote:
Uncertain but thinking '81 550A2 has shim under bucket design, and wondering if cams have been removed and the bucket (lifter
) is stuck or the valve itself is stuck.
If "lift the whole casing off" refers to the camshaft, sounds like shim over bucket design where the special valve adjustment tool is used to hold the valve open and allow shim removal.
Maybe just misunderstanding the question as my experience is with shim over bucket.
Post edited by: Patton, at: 2007/03/18 18:40
... pulled the lifters out w/ a suction cup, but when i got to the #4 exaust its stuck. any inputs?
- Joe
18 Mar 2007 19:19
there is a lifter then a shim under that into the valve casing,spring etc... I can't get the lifter itself out of the engine block itself. to get the valve out, I have to get the lifter out. I'm dumbfounded. I don't want to eat up the lifter, but at the same time it needs to come out.
Joe
Joe
18 Mar 2007 21:53
Here's an archive link with some info that might help.
stuck lifter
Before removing the head to heat in oven, might consider torch heating head area around lifter (hoping greater aluminum expansion would loosen grip on steel lifter).
Hope someone more experienced will add better advice as I'm just guessing.
stuck lifter
- wireman
- larrycavan
18 Mar 2007 22:06
In a case like this, I'd get a can of PB Blaster penetrating oil and heat the area around the lifter with a heat gun after giving the PB Blaster a good shot around the lifter and let it work it's way down between the tappet bore and the tappet.
- nads.com
19 Mar 2007 01:55
put a small wooden dowel on the bucket and tap it genty with a hammer. If it'stuck that should free it. If not...?
- BSKZ650
19 Mar 2007 14:31
use a strong magnet, and rotate it as you bring it up.
if that dosent workit may have a burr on it, use a brass punch and a small hammer, tap around the edges that are up, go all the way around, then try the magnet again
77 ltd1000, current rider
76 kz900, just waiting
- APE Jay
19 Mar 2007 22:38
And when all else fails, with the cam out, you can grab the lifter with a chanel lock plyers and pull it out.
Jay
Jay
