What cam profile should you use in a j- head on a kz-900 with an 1197 kit, 33mm for on the street?
- BigBlockT
18 Mar 2007 06:17
I was going to build my 900 and wandered what cam profile should I use in a j-head with a 1197 kit, useing 33mm mikuni smooth bores, purely street rideing or occasionaly on the highway?
- wallyworld
Re: What cam profile should you use in a j- head on a kz-900 with an 1197 kit, 33mm for on the street?
18 Mar 2007 13:11
probably cam motion z4 or[ z7 for high compression]. both require heavier springs and shorter guides.z7 requires 650 shim under bucket.I have z4s in my 1075 12/1 with 33s stock self ported head. it runs really good around town ,on highway ect .its alittle loapy up to about 2500 from there it starts to cackle to about 3200 where it really kicks in and pulls all the way to 10000.the profiles are at star racing.com.ape has simillar grinds also.I myself ,will be trying the gasser setup on my 1197,[ high lift on the intake]later on, when I get some more time to build this thing. don't know if it will work or not on the street,just gotta try. keep us posted on how yours goes
- larrycavan
18 Mar 2007 22:14
I'd second that nomination for cams.
- APE Jay
19 Mar 2007 01:06
If you want to stay with shim on top, use our K410. If going to shim on bottom, K435.
The 435 is what comes in our 1200cc engine kits and is very popular.
kzzone.com/cams.html
Jay
Jay
- TMOS34
19 Mar 2007 19:02
I am rebuilding my 1975 z1 900, I as well am putting in a 1197 CC with a z5 intake and a z4 ex. with shims under the buckets...I had my crank weld at Falicon, I am running a set of 36mm Mikuni, I ported my own head, and it also has a spark plug head on it....
