dual plug head info
  • 77KZ650
  • 77KZ650's Avatar Topic Author
dual plug head info
16 Mar 2007 14:18
#120791
a very informative thread on www.750turbo.com
LINK
07 MDP Rookie of the Year
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
Re: dual plug head info
16 Mar 2007 14:40
#120800
Whoa!! What's this about?
Oh my EFi isn't that complex, I just split the signal comming from the ECU. I use a GM Dual coil pack for the 10mm plugs.
If you guys want to do a dual plug conversion on your 750. The wiring is very simple! Get a coil pack from a late 90's Saturn 4-cyl. The coil ignitor is built right in. Only 4 wires, ie +12V, earth, left trigger and right trigger wire (negitive side) of your factory coils . Just "tee" into you factory wire harness just at your factory harness.
The built in coil driver does all the work, instant 8 plug setup. Your factory ECU doesn't know anything, because factory coils "fire" by negative wire...
Is he saying that a Saturn coil pack has its own igniter built in? Where's the ignition whiz?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • 77KZ650
16 Mar 2007 14:54
#120802
that would be Lou....
  • steell
  • steell's Avatar
16 Mar 2007 18:34
#120851
I'm not familiar with the Saturn ignition, but I know the Mazda RX7 coils have the igniter built in.
  • wireman
  • wireman's Avatar
16 Mar 2007 21:30
#120920
