Wrong exhaust on bike?
- pilotx253
14 Mar 2007 22:35
77 kz1000 ltd with aftermarket 4 into 2 pipes. I am pretty sure they are aftermarket and they are fairly generic, couldn't find any brand name stamped on them. They use a crossover pipe and from some reading on this forum I am pretty sure this wasn't stock. Will my bike run poorly with the crossover pipe setup? I know the early 80 model ltds used crossover pipes.
1977 KZ1000 LTD
- CoreyClough
- GPz550 Addiction
Re: Wrong exhaust on bike?
15 Mar 2007 05:02
I don't know about anyone else, but I think the only reason cross-over pipes were used was so there was extra support for the exhaust, and it makes changing the oil and filter easier without removing the whole exhaust system. For anyone that is running the stock exhaust, look at the small holes the exhaust gasses come out of at the end of the mufflers. The exhaust is funneled down from the 4 headers to two small outlet holes. Just my opinion.
Pictures? I bet someone could identify them. Aftermarket systems usualy have a stamp on the rear mounting bracket, or a plate on the inside near the rear mounting bracket.
'85 GPz550(ZX550-A2)
- Bluemeanie
15 Mar 2007 05:36
I can't explain the physics but a crossover pipe is used to even out the exhaust pulses between sides and it also boosts bottom end power a little bit without giving up top end. Had them right behind the headers on my muscle cars
- The Gringo
- ¡Usted no necesita otra motocicleta!
15 Mar 2007 06:01
pilotx253 wrote:
Actually what you are describing sounds like the stock pipes which were made for Kawasaki by Jardine.
Edit: Whoops just looked at the stock pipes on the Kaw website and it does not show any crossover pipe:blush: I guess I was thinking of the pipes on my G1 which does have crossover.
Post edited by: The Gringo, at: 2007/03/15 09:09
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Pterosaur
15 Mar 2007 06:09
The Gringo wrote:
A pic would certainly help, but I was thinking the same as El Gringo...
Who went on to say:
Just did the same myself. Yep, no crossover.
Question - do your pipe/crossover junctions look anything like this:
'78 Cop exhaust.
Post edited by: Pterosaur, at: 2007/03/15 09:44
pilotx253 wrote:77 kz1000 ltd with aftermarket 4 into 2 pipes. I am pretty sure they are aftermarket and they are fairly generic, couldn't find any brand name stamped on them. They use a crossover pipe and from some reading on this forum I am pretty sure this wasn't stock. Will my bike run poorly with the crossover pipe setup? I know the early 80 model ltds used crossover pipes.
Who went on to say:
'78 Cop exhaust.
- Pterosaur
15 Mar 2007 06:55
Bluemeanie wrote:
From a previous thread about those horrid Fleabay "X" pipes...
JMKZHI wrote:
Triumph twins had 'em back in the 60's.
Whether a crossover is useful or not is dependent on the size of the exhaust and distance from the engine the crossover pipe is located. A crossover is not required if the exhaust is "tuned" to the engine.
A tuned system doesn't need a crossover pipe because the length and diameter of the exhaust is specifically designed to work with the engine at a specified RPM Range to avoid "reversion" and scavenging.
In some instances, a crossover pipe will decrease backpressure and allow for a higher flow. If a crossover pipe is too close to the engine, it allows the pulse timing of the opposing cylinders exhaust cycles to crash into each other – the pressure from a right cylinder will still be present in the left pipe when the left cylinder opens to vent. Too far a placement can create "pulse vacuum" - diminished pressure on the opposing cylinder and a decrease in torque - called scavenging.
A well designed and placed crossover will allow a balance of pressures across the system and increase torque at lower RPM.
Another reason crossovers got popular is because they absorb pulse energy, they tend to make a mellow-er sound sound than unbalanced pipes.
JMKZHI wrote:
Well, Kawasaki does use a crossover pipe on the stock KZ exhaust, and some of the newer exhaust systems have crossover connectors higher up on the header pipes closer to the engine exhaust ports. The stock ones I've seen have the connectors between the 1-4 & 2-3 header pipes; muzzy sells a set for a ZR7 that has the connectors between 1-2 & 3-4.
- paulie
19 Mar 2007 09:48
pterosaur, trying to visualize this(perhaps poorly), but wouldnt that crosspipe (everything inbetween the two #14 parts in the diagram) interfere with the oil filter cover? would you have to take that crosspipe off every oil change to get at the filter?
oil change is a snap on my bike, but just curious i guess :whistle:
Post edited by: paulie, at: 2007/03/19 12:49
- Pterosaur
19 Mar 2007 10:11
paulie wrote:
Nope.
The crossover pipe is comfortably behind the cover plate for the filter, and width-wise, the plate will drop between the pipes with a little jiggle.
No problem at all.
Nope.
No problem at all.
- H1Vindicator
Last edit: 21 Feb 2013 11:01 by H1Vindicator.
- KaZooCruiser
19 Mar 2007 10:20
Wish I could say the same about my cross-sewer pipe. Thing is ALMOST far enough back to get everything out.
Have to drop out the bolt, then slide the cover forward a little (not easy with hot oil). The bolt hangs up in the filter grommets.
I hate oil changes on this bike.
- paulie
19 Mar 2007 11:06
yea i guess "a snap" might be a bit of an overstatement, as i do have to do a bit of finagling to get the thing out. but i guess i just got decent at getting bolt/cover off after the first few changes. i recall being completely confounded the first time.
good stuff as always guys, thanks!
