KZ1100 - Andrews Cams - No timing marks??
- FloridaBiker
11 Mar 2007 07:54
1982 KZ1100 shaft.
I started to check my valve clearances, and the only marks I can find on the camshaft sprockets are:
ANDREWS EXH
and
ANDREWS INT
Does anyone know anything about these cams, or how to check if the cam timing is correct?
ANDREWS EXH
and
ANDREWS INT
- APE Jay
Re: KZ1100 - Andrews Cams - No timing marks??
11 Mar 2007 08:02
It is an adaptor sprocket and they made them with no marks.
Jay
Jay
- FloridaBiker
11 Mar 2007 08:06
Any suggestions on technique to check my cam timing is correct?
- steell
11 Mar 2007 17:15
FloridaBiker wrote:
The cam specs, a dial indicator, and a lot of patience. Or just order a new set of adapter sprockets from APE (they have marks).
- FloridaBiker
11 Mar 2007 20:38
I am comfortable with the tools.
I don't know any history on this engine.
A sharp bike mechanic told me he thinks it has a big bore kit and that the Andrews cams are probably more pure race than street.
I hope not.
Anyway, since I don't know where to time the cams (no marks or instructions that I am aware of) am I in the realm of trial and error?
I hope not.
- APE Jay
11 Mar 2007 21:50
What is the number of the Andrews cam?
Jay
Jay
- FloridaBiker
12 Mar 2007 05:52
APE Jay wrote:
On the intake cam;
At the timing sprocket:
ANDREWS INT
on the cam (visible from above the engine):
5L R
On the exhaust cam;
ANDREWS EXH
3L R
I can find no other marks except:
* 1 tiny dot on each cam sprocket. It could be construed as a timing mark, but referenced to what?
*2 At the left side at the end of both cams are 4 indexed marks at 90 degree separation.
*3 On the right side at the end of both cams are square notches about 3/16"
Drawings attached. (I got poor picture quality when I tried to take a digital closeup)
Post edited by: FloridaBiker, at: 2007/03/12 08:55
Jay
On the intake cam;
ANDREWS INT
5L R
On the exhaust cam;
ANDREWS EXH
3L R
- outlawz1
12 Mar 2007 06:49
The number should be stamped on the end of the cam and have an X in it if they are andrews. Like 2X 3X etc.
- FloridaBiker
12 Mar 2007 10:21
There is definitely no other number stamped on the end of the cams.
Could it be the 3L and 5R I found on the side of the cams?
The exhaust cam has a worm drive gear that is not in use, between the sprocket and #3 exhaust lobe. Could that be for a tachometer on some other model?
Also there is no double stripe marking on the cam, like the factory 1100 cams.
Could it be a Andrews sprocket and some other cam?
Any ideas appreciated.
- FloridaBiker
- APE Jay
13 Mar 2007 01:16
If it doesn't have the X number, then they are not Andrews. Only the sprockets are.
Jay
Jay
- outlawz1
13 Mar 2007 07:51
Do they have the little notches on one end like your showing in your diagram? If so they are stock z1/kz1000 cams. If you could measure the lift you would know for sure.
