starter spinning/chain?
- clb3carl
10 Mar 2007 13:47
my starter just whirls..not engageing anything could it be as seriuos as the chain inside or is there something else to check for?thanks for ANY help...
- steell
Re: starter spinning/chain?
10 Mar 2007 13:52
Depends on the model of your bike, kinda need to know that in order to answer your question
- clb3carl
- Sixgun
12 Mar 2007 13:30
My 750 twin was doing the same thing. It thought it was the starter, but it turned out the bolts that secured the starter clutch to the dynamo rotor had all broken off. Everytime I hit the electric start, it would spin and the bolts would just sound like rocks in there.
I'm not sure if this will help, but it might give you something to look for.
78 KZ750 B3
81 XS650SH
80 XS650G
81 XS650SH
80 XS650G
- CBerryment
03 Apr 2007 08:24
Hey, Don't know if yo uhave solved this problem or tried this yet.
Inside the starter motor there is a slip gear which allows the starter to disengage rather than get messed up by a back fire or other malfunction. If the bolts holding the starter together are not tight enough, there is not enough friction to hold the slip gear and allow the starter to turn
