not running??
  • kustompup93
  • kustompup93's Avatar Topic Author
not running??
09 Mar 2007 14:11
#118734
hey everyone i have a problem with my 81 kz550. i recently baught some new parts. air pod filters, plugs, wire, oil filter. etc.. i put the all on but the oil filter. i took off the carbs and cleane dthe hell out of them, re installed them and the one that was leaking b 4 is leaking again. anyone know why my bike cant staying running? it will start 2 then stop. its hard 2 get started cause it was sitting for a lil while. ?? any one know wats up?
  • themachine
  • themachine's Avatar
Re: not running??
09 Mar 2007 15:30
#118749
if your mechanical ability is as good as your spelling and grammer take the thing to a mechanic.
if it was running fine before you tore into it its most likely because you did'nt buy a proper carb rebuild kit.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • baldy110
  • baldy110's Avatar
Re: not running??
09 Mar 2007 16:10
#118765
We need more info on your problem like will it take throttle, does it idle at all. does it run only on choke or off? Please be more discriptive other than it won't run.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: not running??
09 Mar 2007 20:44
#118838
Hey kustompup93,
Like fishing do you? You know that there's a special license required to troll the waters of KZR.
Better luck next time.
KZCSI
Post edited by: KZCSI, at: 2007/03/09 23:45
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • arobsum
  • arobsum's Avatar
Re: not running??
10 Mar 2007 09:38
#118946
KZCSI wrote:
Hey kustompup93,
KZCSI<br><br>Post edited by: KZCSI, at: 2007/03/09 23:45
i like this statement...:laugh:
  • austin3119
  • austin3119's Avatar
Re: not running??
10 Mar 2007 09:44
#118952
What am I missing here? :huh:[arobsum wrote:
KZCSI wrote:
Hey kustompup93,
Post edited by: austin3119, at: 2007/03/10 12:48
