kz1100 Exhaust leaks at every connection
- highspeedjelly
09 Mar 2007 01:41
The previous owner of my kz1100a installed a new set of headers just prior to me buying it. It developed valve clatter after a fast 3 hr run recently so I dropped off at the local kawasaki dealer to book it in for the shims to be done and when he looked at the bike he found the exhaust leaking at 2 places at the head and every other connection as well.He says the noise is leaks in the exhaust not valve clatter.
I have pulled the whole system off and fitted new gaskets at every join but the head connection is still leaking and the connector pipe near the oil filter.
Is this a common problem with the stock exhausts ??? Any suggestions ?
thanks
thanks
- Mcdroid
- Gone Kwackers
Re: kz1100 Exhaust leaks at every connection
09 Mar 2007 01:58
What type of header? If you don't know, then a picture of the pipes and canister/muffler will do. It is possible that:
1. these pipes are the wrong application for your model
2. if they are new pipes, then manufacturing quality control issues may affect fit (more common than you think)
3.sometimes you have to put thicker exhaust gaskets on to ensure proper fit ( www.z1enterprises.com has them for Yamaha's but they work on Kawasakis)
Post edited by: Mcdroid, at: 2007/03/09 04:59
Post edited by: Mcdroid, at: 2007/03/09 05:00
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- The Gringo
- ¡Usted no necesita otra motocicleta!
09 Mar 2007 05:10
Since you did not do the install yourself I would be looking at the PO's workmanship. Pull it back apart and make sure that he removed the old copper exhaust gaskets before he installed the new ones. That is assuming he installed new ones. Most times when you remove the stock exhaust the old crush gaskets stay behind in the head and you need to dig them out. The PO may not have known they were even in there.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- highspeedjelly
- The Gringo
10 Mar 2007 16:05
If you are running stock pipes we can rule out poor aftermarket quality control. The only thing that could be wrong is poor installation. Pull everything back apart and pay attention to where the exhaust gaskets/copper crush gaskets seat. I'm betting that the old gaskets were not removed prior to installing new ones. You should have only aluminium visable where the gaskets seat, take a screwdriver or a pick of some kind and make sure of this before you re-install the exhaust.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- KZQ
- Administrator
10 Mar 2007 18:06
I've found that many of the after market exhaust systems have flanges that are thinner than the stock flanges. As a result the collars bottom out before the gaskets get crushed tightly.
Here goes, Flame on.
When mounting an after market system with thin flanges I first make sure that the old gaskets are intact and still in place and then I put a new gasket over them and tighten em down.
It's always worked for me.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- pstrbrc
- '81 GPz 1100 project
10 Mar 2007 18:57
Hold on a sec, guys. He said:
So he's not just talking about the head-to-downpipe flange, he's also talking about either where #2 connects with #1, where #3 connects with #4, or the connection in the middle of the crossover pipe. And the only reason I'm interested is that I forsee a similar problem. I'm putting an exhaust off of an '82 KZ1100 on my bike, and when I was disassembling them to clean and paint, I found what appeared to be some sort of gasket material baked around the part of each pipe that inserted into another, and when I cleaned everything up, I've got at least 1/8" of excessive clearance. WT*?? Is there some material that the factory used on these to seal? Something like what they sell for muffler bandages?I have pulled the whole system off and fitted new gaskets at every join but the head connection is still leaking and the connector pipe near the oil filter.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- highspeedjelly
13 Mar 2007 04:19
Thanks GSX1100e gaskets are 5mm thick and have stopped the leaks at the head.
- highspeedjelly
13 Mar 2007 16:32
Thanks GSX1100e gaskets are 5mm thick and have stopped the leaks at the head.[/quote]
Sorry they are gs550 gaskets
part number 14181-05020
