help
  • DaytonaMC
  • DaytonaMC's Avatar Topic Author
  • You keep for your collection, I know you like it.
help
07 Mar 2007 20:21
#118263
i am in need of some help. i have just installed my camshafts and, i am trying to tighten them down but, i am having a hard timegetting them just right, i used the tightening sequence in the manual but, for some reason, it is not working to my advantage. is there a secret to getting the cams on right? i have a 1977 kz1000ltd.
Post edited by: DaytonaMC, at: 2007/03/07 23:23
I must remove my skin.....
Re: help
07 Mar 2007 20:33
#118282
Stripping female threads in the head can be a problem.
Here's one of the links from a search on "cam bolts"
cam bolts
Recall bearing inserts under the cam caps should go back in their original locations.
Post edited by: Patton, at: 2007/03/07 23:42
  • DaytonaMC
Re: help
07 Mar 2007 20:42
#118286
thanks i aprecciate your help, i hope i figure this out.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: help
08 Mar 2007 05:06
#118311
There is some side play when you just set your cams in place... make sure you have them centered or you may be catching a lip which isn't allowing them to seat.
  • DaytonaMC
Re: help
08 Mar 2007 05:31
#118324
thanks a bunch. i am tryinhg to figure it out. i was reading threadnamed cam bolts and,i saw where it said that the service manual promotes ripping the threads out.is there a certain way you would suggest?
