Engine Forum
Engine forum is a tech forum for "Engine" topics.
Fuel consumption of Z1000?
  • jeffreygp
  • jeffreygp's Avatar Topic Author
Re: Fuel consumption of Z1000?
01 Mar 2007 09:43
#116392
I already cleaned the carbs and tried changing to diffrent clip positions, but there is no diffrence in fuel consumption. It is now at the second to the lowest clip groove anything higher and it starts to pop off thru carbs. And I have 3/4 turns on the adjustment screws. Plugs are always a little black and sooty. :)
  • arobsum
  • arobsum's Avatar
01 Mar 2007 10:52
#116404
the lower you go on the needle with the clip grooves, the richer the carbs are. try going the other way. move the clip closer to the top of the needle. this will make it leaner.
  • jeffreygp
01 Mar 2007 11:21
#116410
When I go higher with the clip grooves, it pops off thru the carbs. It means its too lean,right?:)
01 Mar 2007 11:29
#116414
If pilot mixture screws are on the carb side, only 3/4 turn out may be too rich as this would not let enough air into the idle circuit. Believe starting point should be 1 and 1/4 -- then screw in (clockwise) to get richer and screw out to get leaner.
If pilot mixture screws are on the carb bottom, only 3/4 turn out may be too lean as this would not let enough fuel mixture into the idle circuit.
Plug reading indicates too rich.
Perhaps already mentioned, but is the air filter clean and unobstructed?
Has actual on-the-bike service fuel level been checked to see if it's too high? This can cause excessively rich mixture with an otherwise perfect carb. Use the clear plastic tube method (described in other threads).
Would not rely on the upside down measured bench adjustment method of setting the float height, because it may fail to result in a correct actual fuel level.
Just throwing some ideas, and wish you good luck. :)
01 Mar 2007 11:32
#116415
Underinflated tires can also result in lower fuel mileage.:)
  • pyxen
  • pyxen's Avatar
01 Mar 2007 11:48
#116421
..and life expectancy!
84 KZ550-F2 LTD
93 ZR550-B4
  • jeffreygp
01 Mar 2007 12:08
#116430
Thanks, I'll check the fuel level with clear plastic tube method. And back out the adjustment screws.:)
Post edited by: jeffreygp, at: 2007/03/01 15:11
  • nads.com
  • nads.com's Avatar
04 Mar 2007 12:43
#117290
you have weak spark and are not burning all the fuel.
  • gpzrox
  • gpzrox's Avatar
04 Mar 2007 13:20
#117295
Nads got there just before I did I see.
Probably a problem with the ignition.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
  • arobsum
  • arobsum's Avatar
04 Mar 2007 16:24
#117331
bingo.
