hard welding header?
- martijn
26 Feb 2007 11:15
I'm planning to make my own header and muffler and I would hard solder the header on the pipes (solder meltingpoint approx 670 celsius). Should this do fine???
Martijn
Martijn
- kzsr810
Re: hard welding header?
26 Feb 2007 12:17
solder? I think you might have to weld this, solder will fall apart after the first bump you hit
- BSKZ650
26 Feb 2007 14:09
will have to be either tig or mig welded if you want it to last
77 ltd1000, current rider
76 kz900, just waiting
- 77KZ650
26 Feb 2007 14:29
I dont think it would hold up or stick very well. if you cant have it welded, a braze might be the next thing to look at
07 MDP Rookie of the Year
- flht1997
26 Feb 2007 15:15
670C is about 1300F you could almost braze with that and get a much stronger joint. you really want to be about 1500F to braze. any non-structural joint i do on my bikes i braze, 1- cause i like the smell of my flux coated brazing rods and 2- it sure looks purdy.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- indykaw77
26 Feb 2007 15:52
Well...I know it's harder than it looks....and I'm just cobbling up a collector. Wire feed flux-core is what I'm using, 'cause thats all I got!! Welds are ugly in spots, but sound.
Measure EVERYTHING 2-3 times before committing to the heat....trust me on that one.
Kawasaki Motorcycles...because cars lean th wrong way!
- wireman
26 Feb 2007 18:58
silver solder is some pretty good stuff on copper,never tried it on steel though;)
- martijn
27 Feb 2007 07:54
You hit the nail Wireman! after a while I was thinking of making them from copperplate. I do have all tools for making a header and "muffler" using copper and best! it does not rust:woohoo:
- pyxen
27 Feb 2007 08:29
though it will turn green...?
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- geerbangr
27 Feb 2007 09:25
Silver solder is the ticket for copper . :woohoo: Just get your wallet out cause the shits not cheap . You'll think your buying jewelery for your wife . Cause you have to buy silver solder buy the troy ounce . Just think of it as buying jewelery for the kz .:woohoo: :woohoo: :woohoo:
Although I swear by the almighty tig torch !!!!
Post edited by: geerbangr, at: 2007/02/27 12:34
1978 KZ 1000
I go by Jason
I go by Jason
- wireman
27 Feb 2007 09:55
you can buy sticks of silver solder like they use for refrigiration work a lot cheaper than the jewelry stuff,ive still got some sticks of it somewhere;)
- martijn
01 Mar 2007 11:38
pyxen wrote:
Kawagreen I suppose??
I'll think I give it a try:P
