Exhaust pipe temperature?
- halfgallondent
25 Feb 2007 11:52
One of the symptoms my 82 KZ750 4 cylinder bike is experiencing is that the #1 and 2 exhaust headers are not NEARLY as hot as the #3 and 4 headers when the bike is fully warm.
What should the temperature be when all 4 cylinders and carbs and everything are properly adjusted and the bike is running right? I have a laser thermometer I can point at the headers to determine their temps.
If I knew what temp the headers should be, I could figure out whether 3&4 are TOO HOT or 1&2 are TOO COLD. That way I reckon I could narrow down which carbs/plugs/wires and so on that I need to adjust.
- JR
Re: Exhaust pipe temperature?
25 Feb 2007 12:19
I dont know of an exact temperature but each pipe should be hot enough so that when you spray water on em it sizzles right off. If it dont sizzle then it's not firing, At the other end of the spectrum you dont want a red hot pipe either.
It might be a good idea to take a look at the spark plugs and see what colour they are. This link might help with plug colour
ngksparkplugs.com
Post edited by: steell, at: 2007/02/25 16:01
ngksparkplugs.com
- hmondo
25 Feb 2007 12:19
I noticed this as well on both of my bikes, but I can't figure what would cause this. If anyone has a potential explanation...I'm willing to listen.
Thanks in advance!
Thanks in advance!
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
1987 ZL1000
- hmondo
25 Feb 2007 12:22
Both of my bikes run great; sparkplugs are the right color and carbs are in sync. No redhot pipes or discolored (blue) pipes here.
1987 ZL1000
1987 ZL1000
- H1Vindicator
Last edit: 21 Feb 2013 21:26 by H1Vindicator.
- KZQ
- Administrator
25 Feb 2007 16:50
Hey HGD,
Given that the ignition is a dual system that runs 1 & 4 on one coil and 2 & 3 on the second coil. And Given that the #1 and 2 exhaust headers are not NEARLY as hot as the #3 and 4 headers when the bike is fully warm.
I'd bet You've got a carb problem.
Might be:
intake leaks
plugged jets
Different float heights
Where's WG when you need him?
KZCSI
Might be:
intake leaks
plugged jets
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- halfgallondent
Re: Well here I go and I'm in DEEEP NOW!
25 Feb 2007 20:22
Thank you all once again for your advice and for taking the time to help a brother out.
Well, I have made an important, life-altering decision today. I had pulled the carbs out, and removed the tank and air pods, and some other things, when it suddenly occurred to me...
I have two bikes and two cars, and they all run great. So what's stopping me from going postal and starting a down-to-the frame restoration on my KZ beater?? So now it's in even more pieces, and the paint has come off the tank.
I am going to learn as I go, because I know nothing about motorcycles. I know nothing about working on cars, even. But I am going to learn a lot!
I'm going to repaint, replace, fabricate, rebuild, tune up and customize until my head spins. Wish me luck!! And be ready because I'm going to be asking advice every five minutes for the next six months...that is, provided my ass don't get sent to Afghanistan.
- martijn
26 Feb 2007 06:11
You didnt'tell how it rides and if it has power...Besides checking carbs I would check valve clearance!
- halfgallondent
26 Feb 2007 18:43
Well, it handles great but it is incredibly SLOW. It accelerates like my grandmother and it topped out at 67 MPH on the freeway. It only gets about 28 MPG. Or, I should say, it WAS incredibly slow. It doesn't move at all now...it's in pieces!!
Oh, and when I say slow, I mean it was so slow that my 4 cylinder Toyota economy car would absolutely SMOKE it off the line.
- trippivot
27 Feb 2007 07:48
270~390F 2-3 inches from head approx you know give or take a bit--has to be over 212 and somewhat equal or you have some carb tuning to do
plug wire end cap resistance
float levels
mixture settings
fuel supply/ delivery
float levels
mixture settings
- H1Vindicator
Last edit: 21 Feb 2013 11:08 by H1Vindicator.
- RonKZ650
27 Feb 2007 12:05
I don't know the temps, but for sure an infrared thermometer will not work on chrome, so if your pipes are chrome don't bother and also if you have an infrared thermometer it has to be a good one with at least a 16/1 ratio to measure a small area accurately. You can measure chrome if you cover it up with masking tape and measure the temp on the tape, but then you need a high temp rated masking tape or it will make a gooey mess in less than 5 seconds. Just a little info.
