engine flush???
- steveo_4192003
- 77kz650b-1
engine flush???
24 Feb 2007 14:24
is there a good way to get the crud that fell in the engine out? im replacing gaskets and some dirt and a few small pieces of gasket feel in to, belly pan is off and looks to be most fell right through.
can i just get a can of carb cleaner and spay it out
or will that not be good for it?
fill it up, and shake it out!!! lol!!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- steell
Re: engine flush???
24 Feb 2007 15:28
I wouldn't use carb cleaner, that will remove all lubrication, I use kerosene.
- H1Vindicator
Last edit: 21 Feb 2013 21:25 by H1Vindicator.
- steell
Re: engine flush???
24 Feb 2007 16:18
Kerosene is pretty much the same as #1 diesel, and if you are in the cold country the diesel sold at the pump is a mixture of #1 and #2 (with additives to prevent jelling), so yes, Diesel will work just fine
- pstrbrc
- '81 GPz 1100 project
Re: engine flush???
25 Feb 2007 06:06
Man, I'm just a little more conservative. I'd recommend ATF. It's real oil, witha whole lot of detergents. Especially if you've got a couple of quarts that are so old they aren't rated for your wive's cage tranny, PERFECT. The problem with diesel and kerosene is that they both have solevent characteristics.
In fact, wasting a bottle of 10w-30 would be even better, 'cause you're not looking for solevent, you just want an inside-of-the-engine rinse, and what better than the motor oil that's meant to be used for that?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- H1Vindicator
Last edit: 21 Feb 2013 21:26 by H1Vindicator.
- kzwolfsr
Re: engine flush???
25 Feb 2007 18:09
I like the sound of that ATF
Original man of the Caribbean
- steveo_4192003
- 77kz650b-1
Re: engine flush???
25 Feb 2007 23:34
wd-40? super!! it this ok to use, and wont hurt any other parts inside of case? sounds good to me, good pressure (with straw) and very thin as to run out bottom of case, just what i need. just wanted to get a second opinion on it before i ruined any internal parts!
all i really need is peice of mind that i can get dirt of crank and drive chain in case, it seems that the dirt from the cyclinder block studs fell in as i lifted it of the case,(common) as well as some small pices of gasket also. any advice for milage of oil change? i WILL change oil about 10-15 miles (is this good) afterwards and then agian around 40-50 just be be shure!
if i get the ok to use wd-40 its a done deal and thanks for the second opinion in advance!!!
- MDawnz1
Re: engine flush???
03 Mar 2007 22:52
How about starting with air to blow it out ?
If you dont have a compresser ,
what about a can of canned air for cleaning out computers ?
With a piece of windshild washer hose over the straw it should get just about everything loose out .
1974 Z1a, still 903
