Transmission Woes \"chunk chunk chunk\"
  • kkant
  • kkant's Avatar Topic Author
24 Feb 2007 08:02
#114945
Hi folks. I have a KZ1000 police bike. Under moderate to heavy acceleration, the transmission is slipping. It doesn't pop out of gear, but it "chunks" as the cogs slip partially out of the gear and back in again.
I took it into a shop, and the guy "tightened it up", and it started working great. Now it is slipping again. Question is, how do I fix this? Anyone know how I can "tighten it up" to stop it from slipping?
  • wireman
  • wireman's Avatar
Re: Transmission Woes \"chunk chunk chunk\"
24 Feb 2007 08:51
#114968
what did he tighten up on transmission without tearing into motor?:blink: are you sure its not your clutch slipping?transmission is gear to gear ,it dont slip it chews parts up!;)
  • kkant
24 Feb 2007 09:28
#114980
Yeah, I'm pretty sure it's not the clutch, because it is a harsh chunk or series of pops when it slips--as if the dogs on the gears are coming out of the recesses and shifting to the next slot. And yeah, I agree, it must be tearing parts up when it does that...right now I ride the bike pretty gently so it doesn't pop.
The mechanic probably took off one of the covers, and he might have tightened a clutch nut or something. Problem is, I don't know exactly what he did. Looking for ideas as to what that might have been, so I can do whatever he did. Any ideas?
  • BSKZ650
  • BSKZ650's Avatar
24 Feb 2007 12:23
#115036
have you looked at the front sprocket nut, mine got loose and then came off, it sounded like the trans was comming apart
77 ltd1000, current rider
76 kz900, just waiting
  • Z1R rider
  • Z1R rider's Avatar
25 Feb 2007 05:37
#115202
could be worn chain and or sprockets
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
25 Feb 2007 05:45
#115204
Good idea about the chain. Perhaps badly kinked and "tightened it up" may have referred to slack in the chain. :)
  • kkant
25 Feb 2007 12:41
#115293
Good thinking, sprocket or chain. I'll check those out. Thanks for the replies!
  • arobsum
  • arobsum's Avatar
25 Feb 2007 13:26
#115300
my kz1000 developed a "chunk, chunk"....it was a sticky link in the chain. a little lube fixed it right up. good luck. :)
25 Feb 2007 14:48
#115326
If an o-ring type chain, when it reaches the point of needing outside lubing to avoid kinking IMO it's then time for replacement. By this time the "permanent" internal lube is mostly gone and the chain is pretty well shot.
  • kkant
26 Feb 2007 15:05
#115621
Well, folks, I went ahead and tightened up the chain. Turns out it was a ways out of adjustment, 2" of play or so. Tightened that up to 1.25", and problem solved!!
Thanks again for your help! :)
  • pyxen
  • pyxen's Avatar
27 Feb 2007 05:29
#115736
who needs a mechanic when you've got KZr!?
That's awesome B)
84 KZ550-F2 LTD
93 ZR550-B4
